Old 03-15-2018, 01:53 PM
ALLZS ALLZS is offline
Default 68 nova rear wheel back space
Anyone running ss cragers on there nova wanting to put the largest tire & wheel with out folding up the rear quarter lip needing to go with 15 inch tires 15x8 rear 15x 7 front thanks
Old 03-16-2018, 01:12 AM
cwc's Avatar
cwc cwc is offline
15x8 with a 275/60 will fit with 5 1/2 backspace, I don't know if cragar will custom make or not. I have 15x7 with 4" backspace and L60's
1967 SS427 4 speed triple black survivor-sold to a good home
1969 nova SS396 L78 4 speed triple black survivor
1970 camaro SS350 citrus green,Dad bought it new!
1968 chevelle ss396 L34 M21 KK rear all born with
1972 formula 400 M22
Old 03-16-2018, 03:08 AM
Don't you have to roll the lips when fitting 15 x 8 rims and 275/60 tires on a nova?
Old 03-16-2018, 04:18 AM
cwc's Avatar
cwc cwc is offline
Nope,but I did have to run 1/4 spacer on one side to keep tire off shock.
Old 03-16-2018, 12:06 PM
H70 I used to run on the back in the early 70's with a 7" rim. No issues. I like 7" wheels in the back and 6" wheels up front. 7's in the front are to wide for me. JMO
Not sure an L60 will fit without a wheel well wrap up because you may have to run a spacer to keep tire off the shock.
Air shocks would help.
I have also run 6" Cragars on the back with L60's and spacers with no issues anywhere on a camaro. Trial and error.
Old 09-21-2018, 09:57 PM
MonteMike79 MonteMike79 is offline
Didn't want to start a new post and thought this was close,
I have a '69 Nova and want to go to bias tires. Firestone 6.70/15 in the front, the rears I would like to have a bias but want to keep my tail pipes and don't want to raise the rear. Was looking at the Coker L78-15 with a 7" wheel. What do you guys think ? Also saw Camaro in Muscle Car review running the new MT sportsmans and looked at those, but would like a more vintage tire tread if I could. Also looked at the MH 275/60 but they say to use an 8" rim minimum. Would like to run the Pro Tracs but they say the same thing.
Thanks for any and all help/pictures.
Mike
'83 Monte Carlo
'69 Nova
'62 Bel Air 'bubble top'
Old 09-21-2018, 10:24 PM
GrumpyJeff's Avatar
GrumpyJeff GrumpyJeff is offline
I'm running the M&H 275/60's on a 7"Cragar with out any issues, actually look real good !
Old 09-21-2018, 11:44 PM
PxTx's Avatar
PxTx PxTx is offline
I had the vintage Keystone modified to a 15x8 and am running the M&H on my sister's 69 Nova. It is tight but if you want to make them work, you can.
To stay off the shock, there are options with relocating the lower shock mount, via a traction bar or simply using a shock that doesn't have a tin dust shield.
I post a pic in a bit
Paul III
Old 09-22-2018, 12:24 AM
PxTx's Avatar
Paul III
Old 09-22-2018, 03:47 PM
cwc's Avatar
cwc cwc is offline
I run 6.40 on my 15x4 and love how they fit
