67 low horse 327 divorced choke tstat
Need the divorced choke thermostat with cover, and the linkage that goes to the carb from the tstat for a 67 327 210 horse Camaro.
Repop is OK. Not for my car. Need the same set up for a 69 Z/28, but posted in another thread.
Got the one for the Z.
I may have one that will work on the 327, but would rather get the correct part. Any of you guys with parts books that can get a part number for the choke coil? I probably have a cover that will work and can make the linkage. Just need a part number for the choke coil so I can start looking. Thanks for any help.
Lynn,
Looks like you're after GM #3908966 and used on most small blocks w/2 BC in the 60's. I don't have one to give you but hope this helps. |
Thanks for the info. That is what I just concluded about 30 min. ago. Found one on ebay and bought it.
Thanks again.
