Old 12-05-2018, 02:43 AM
That's a beautiful 12 bolt!
Old 12-05-2018, 03:09 AM
Super nice Rick! X2 on the rearend but it certainly applies to E-V-E-R-Y thing. Agreed with the cost and I'm on the same path with my '69 L78 134 car. It bleeds the wallet but the green is replaced with a constant smile.
I did notice your brake distribution block was brass, that appears to be a mid '69 changover from the cast version.
Your thread has filled a couple voids of info. on my own resto so thanx for that!
Old 12-05-2018, 11:51 AM
Wow...just wow! Looking great Rick and Annie. Rick being anal, who knew?
Old 12-05-2018, 12:18 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Stunning -
Jake Dykstra
Dykstra Motorsports
Old 12-05-2018, 03:22 PM
SS427's Avatar
SS427 SS427 is offline
Not to compare them to the 1970 Chevelle but I believe that to be a vendor supply thing as it is plant dependent on 70's from what I have seen and that was all year. Someone please correct me if I am wrong but I have many dated units of both styles to confirm this.
This particular Chevelle came with the brass unit and this is the very unit that was with the car after I restored it.
Rick Nelson
Old 12-05-2018, 08:11 PM
JoeC JoeC is offline
Originally Posted by SS427 View Post
Since last posting we have worked virtually every night and all
The fuel vent tubes were original so I simply cleaned them up and restored the original square tipped clamps. I found remnants of the old filter material in side the vent lines so using a heated bullet casing I hot cut new vent filters from foam from a garden tractor. After closer examination of the hose line bracket it looked to have been original phosphated so I re-phosphated my original, restored the screw and the rest of the electrical and hardware.
I think the 1969 Chevelles used a plastic fuel tank vent valve
they sell it has fitting 1968 to 1970 but some say it is 69 only?
I know they used to be hard to find so people would replace them with a home made unit.
it used to be hard to find but they repop it now
https://www.opgi.com/chevelle/CH28013/
Old 12-05-2018, 08:24 PM
SS427's Avatar
Thanks for the input Joe. A ton of research has been done on this fuel surge plastic piece since I originally tore the car down. You are right that many of the 69 Chevelles used this piece but not all. This was determined by not only looking at some unrestored survivors but also really looking hard at our car as it was disassembled.
For starters, there are two different bracket designs. One for the 2 fuel vent line mounting and one for the plastic vent mounting (see photos). My bracket that is on my car will NOT fit over the plastic vent. If you mount my bracket on a car with the vent, the vent will simply try and flop over. Also, the ones with the vent had a foam material in the vent opening while mine had the same material within the hose itself. I have confirmed this with a couple of survivor COPO owners so I have no doubt this to be correct. I am a firm believer in "never say never" and believe that mine is the correct way for our car.
Rick Nelson
Old 12-05-2018, 08:37 PM
Donnie's Avatar
Donnie Donnie is offline
heres a pic of the sending unit you need Rick. for some reason I cant upload pics from my computer
http://img.photobucket.com/albums/v6...n2013/1055.png
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 12-05-2018, 08:49 PM
SS427's Avatar
I have to admit, I have never seen one like that before. More research needed I guess. I can only imagine how hard one of these will be to find. I cannot seem to get it to post here either due to it being an .png file.
Rick Nelson
Old 12-05-2018, 09:11 PM
Donnie's Avatar
thats the original from my car. have Sam send you a pic of the one on his black L78 its the same.
69 SS L78 Chevelle
70 SS 396 Chevelle
