Old 12-06-2018, 10:23 AM
fiveforty fiveforty is offline
Default 69 Z28 Same casting date as pad date.
Has anybody ever seen the same date? Hugger Orange 69 Z28 RS in NC on EBAY. Casting says C-12-9 and pad is V0312DZ.
Old 12-06-2018, 12:44 PM
jdv69z's Avatar
jdv69z jdv69z is offline
Yes, it is possible that engine assembly occurred same day as block was cast.
Jimmy V.
Old 12-06-2018, 04:08 PM
I believe I have seen two. Also had a block that was only one day apart.
not the norm, but possible.
Old 12-06-2018, 05:44 PM
Steve Shauger's Avatar
Administrator
There are a few examples of identical dates.
www.yenko.net
www.vintagecertification.com
Old 12-06-2018, 05:47 PM
AGREED with above. Not common but has occurred.
Mike
Old 12-06-2018, 07:15 PM
jdv69z's Avatar
My assembly date is 0912DZ; Cast date is I108. 2 Days.
Jimmy V.
Old 12-06-2018, 09:03 PM
MJV1953 MJV1953 is offline
My 1966 Corvette 327/300 block was cast 11/22/65 and assembled 11/23/65.
Old 12-06-2018, 09:37 PM
TimG TimG is offline
I've had same day cast/build dates on small blocks. As long as everything looks good, don't worry about it. The built them "warm" sometimes. :-)
Old 12-07-2018, 07:07 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
124379N624053
Interestingly the ad says both 186 heads are dated C219.....
Tim in NSW, Australia
Old 12-07-2018, 01:42 PM
rlw68's Avatar
rlw68 rlw68 is offline
Maybe just a typo ? Assuming C129 the heads were also cast on the same day !
Originally Posted by ZLP955 View Post
124379N624053
Rob
