Old 12-07-2018, 04:58 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Would have to see the stampings to verfiy.
That trunk and quarters look like they need rust repair.
Old 12-07-2018, 10:11 PM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Originally Posted by rlw68 View Post
Maybe just a typo ? Assuming C129 the heads were also cast on the same day !
Even if it was a typo, and should be 12th not 21st, that would mean the block and both heads were cast, machined, assembled together and stamped all on the same day.
Tim in NSW, Australia
Old 12-08-2018, 03:02 PM
Jeff H Jeff H is offline
My 302 is cast C 14 9 and the assembly date is V0321DZ so if that engine was really assembled on 0321 instead of 0312 it would fit in pretty well.
Old 12-08-2018, 06:28 PM
Any opinions on the quality of a block that is cast and machined on the same day? My tool&die background would make me a bit wary of machining a block when in theory it could still be cooling? I would think 2 or 3 hours minimum to fully cool. Maybe they sequenced them OK. Was the Pad stamp done when the engine was fully assembled and ready to leave Flint? I suppose it could have been cast on 3rd shift and finished and stamped on 2nd shift (same day).
Owned since 1978 - First Car
Old 12-09-2018, 12:08 PM
x33rs x33rs is offline
Here's one way to think about it. Many machinist, even back in the day, when blueprinting these things would re-hone cylinders while running hot water through the block to simulate temperatures during running conditions for more accurate machining since things expand and contract. Just a thought.
The Following User Says Thank You to x33rs For This Useful Post:
PeteLeathersac (02-06-2019)
  #16
Old 12-10-2018, 07:16 PM
YENKO DEUCE REGISTRY's Avatar
On certain build weeks of Deuces, the Z28 engine needs to be but a few days apart - or we become suspicious....
Marlin
