Old 12-17-2018, 03:33 AM
Canuck's Avatar
Canuck Canuck is offline
The paint depth guages will measure in mm.
www.vancouverclassiccars.com
Old 12-17-2018, 12:36 PM
L16pilot L16pilot is offline
"A good example of this is at the ends of the quarter panels were we found depths of 7mm due to end of spray patern."
Just to offer some clarification...1 mil = .001"...or one-thousandth of an inch. Coating thickness is typically measured in mils which should not be confused with millimeters (mm). 7mm would be the equivalent of .276"...or more than 1/4".
However, I do agree with Paul's overall and I use 3.5-4.0 mils as a target nominal. Due to spray patterns, I've see upwards of 6 mils and anything over 6.0 mils is cause for further scrutiny.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
The Following User Says Thank You to L16pilot For This Useful Post:
jerry455 (12-17-2018)
Old 12-17-2018, 02:45 PM
Canuck's Avatar
Thanks for clarifying depth.
