Old 12-20-2018, 03:26 AM
HuggerSS HuggerSS is offline
Default WTB 1968 Z28 Oil Pan
I am looking for a 1968 Z28 original oil pan. Any help would be greatly appreciated!
Old 12-23-2018, 03:13 AM
Lynn Lynn is online now
I know where a 69 pan is available. Assembly line correct; not one of the over the counter pans. Aren't 68 and 69 identical except for the drain plug?
Old 12-23-2018, 04:43 AM
I am not sure if they are the same. Can anyone confirm they are the same?
Old 12-24-2018, 04:41 AM
Apparently 67 and 68 Z used pan 3927134
69 used pan 3974251
I know for certain that the drain plug is different. 67-68 used the large hex head drain plug. 69 used the smaller 9/16 hex head with the same thread.
I also believe that even a slight change (like the different drain plug) would call for a different part number. But I don't know if there are any OTHER differences in the two pans.
Can anyone help this member out? Surely with all the knowledge on this board, someone knows.
Old 12-24-2018, 04:48 AM
Thank you for the information!
Old 12-25-2018, 01:45 AM
302moz 302moz is offline
Default 68 oil pan
The 68 oil pan uses the same 9/16 hex size drain plug . I have a really nice true assembly line 68 z pan I would sell . Call or text thanks
