Old 01-17-2019, 06:39 PM
SS427's Avatar
SS427 SS427 is offline
Originally Posted by Woj View Post
Where do you source the tubular rivets for the cowl vent doors? Phil
Ace Hardware Phil. I get most all of my specialty rivets (excluding ball joints) from them. They are not cheap even when bought in bulk and I usually buy a quantity at any given time so I have enough in my inventory. They even have the rivets used on the grille brackets. However, the tool is another thing and if you want to use the correct rivets you also need the correct tool and there are several different sizes. I don't recall where I bought mine but they are readily available on the net.
Rick Nelson
The Following User Says Thank You to SS427 For This Useful Post:
Slob44 (03-23-2019)
  #292
Old 01-17-2019, 06:44 PM
Nice component restoration Rick. The wiper motor is like fine jewelry and the kick panels look factory fresh.
Thanks.
Phil
Here's where I got mine:
https://www.mcmaster.com/catalog/125/3439
They sell the tools too.
Owned since 1978 - First Car
Old 01-17-2019, 06:55 PM
SS427's Avatar
For those doing their own kick panels, this is the product I use to seal them against the interior side walls, DS-110 Duct Seal. This matches the original to a T, is easy to work with and seals them from water leaks. You can get this at most big box stores in the electrical department. On average it will take pretty close to the whole brick to do one pair of kick panels. I slice the brick into a ribbons about 3/4" wide length wise and roll it between my palms until you make an approximate 3/4" to 1" diameter rope. I would rather use too much in this area than not enough as water leaks are not good.
Rick Nelson
The Following 2 Users Say Thank You to SS427 For This Useful Post:
L_e_e (01-18-2019), McCune (01-17-2019)
  #294
Old 01-17-2019, 08:20 PM
mssl72's Avatar
mssl72 mssl72 is offline
God, this thing is so nice... I quit. I'm sellin' everything...
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 01-17-2019, 09:21 PM
How did you fix the cables?
Old 01-18-2019, 12:30 AM
DarrenX33's Avatar
Looking exceptional Rick.
1969 Z28
1972 Corvette
Old 01-19-2019, 04:38 PM
TDC_1969 TDC_1969 is offline
WOW!!! Great work!
Old 01-19-2019, 05:46 PM
David C. David C. is offline
Excellent attention to detail. Thank you for sharing your processes with us so that we may use your techniques in our own projects.
Dave C.
Old 01-20-2019, 03:23 PM
ban617 ban617 is offline
Hi , fantastic progress on this Chevelle...I have a question about the rear brake backing plates those were originally clear/ silver Zinc ?
Old 01-20-2019, 03:24 PM
Also would this pertain to all 69 cars ?
Thanks again Rob
