Old 02-07-2019, 03:16 AM
ban617 ban617 is offline
Default Restoring Trim
Hi , what is the recommended process for removing anodize from original aluminum trim that won’t eat the aluminum so it can be polished. ??
Thanks Rob
Old 02-07-2019, 12:25 PM
m22mike's Avatar
m22mike m22mike is offline
Last time I did it I used Drano crystals I got at the box store, HD oven cleaner my still work as well . Keep an eye on it and don't leave it overnight
Also check out the videos on you tube, that my be helpful too.
I did the rear panel moldings on my 69 Chevelle and cleared them and polished the clear.
Mike
Old 02-07-2019, 03:14 PM
HD oven cleaner and some 0000 steel wool then tap the dents out, file sand and polish.
They will oxidize fairly quickly if you don't re-anodize them- OR maybe clear powder coat, GUESS you could use catalyzed clear coat/however if it chips or scratches it will tarnish.
Old 02-07-2019, 03:29 PM
Thanks for the help
Old 02-08-2019, 11:26 AM
jasonL78 jasonL78 is offline
you can buy a powder to mix with water. Eastwood used to sell it. I didn't have good luck with oven cleaner.
Looking for the next project.
Old 02-12-2019, 01:53 AM
Ok , thanks Jason
Old 02-12-2019, 01:55 PM
Might try this:
https://www.caswellplating.com/anodi...-solution.html
I haven't myself (yet), but it is a brite-dip anodize not the trim so it should be the right stuff. If you do try it, please report back.
Owned since 1978 - First Car
Old 02-12-2019, 08:51 PM
earntaz earntaz is online now
Originally Posted by BCreekDave View Post
Might try this:
I stripped the anodized surface on moldings from my 71 Nova. Polished them to a chrome-like finish and sprayed Boeshield T-6 on them to protect ... Craig
