Old 02-18-2019, 06:58 PM
earntaz earntaz is offline
Default Holley reverse idle metering blocks
Holley Experts -- is there a way to identify a standard vs a reverse idle metering block? Thanks is advance!! Craig
Old 02-18-2019, 09:35 PM
Disregard (unless I am wrong). Seems the metering blocks are much the same. The difference is an extra port from the metering block into the primary bore below the venturi ...
