Old 03-20-2019, 04:56 AM
Old 03-20-2019, 04:57 AM
Old 03-20-2019, 04:58 AM
Craig_Maiorana (03-27-2019)
  #5657
Old 03-20-2019, 04:59 AM
Old 03-20-2019, 05:00 AM
454_Malibu (03-21-2019)
  #5659
Old 03-20-2019, 05:01 AM
1963 426 Max Wedge Plymouth Savoy
On June 1, 1963 Chrysler released it's new 426 CI Max Wedge due to a rule change by both the NHRA and NASCAR raising the cubic inch limit to 427.
The 426 Max Wedge option was a complete package which consisted of either the 415 HP (11:1 Compression) or the 425 HP (13.5:1 Compression), HD 3 Speed Torqueflite Auto Trans and 3.91 gears in a Sure-Grip HD rear. Other standard features were a dual point distributor, "Laker" exhaust cutouts, 10" drum brakes and deep groove pulleys. These cars were very capable of hitting high 12s with open exhaust and a set of slicks. The 415 HP model could be driven on the street (with limited success due to the cross-ram intake manifold which was designed to work at 4000+ RPM) using Sunoco 260 but the 425 HP version required racing fuel (110+ octane)
Due to the late introduction date, only 18 426/415 HP Max Wedge Auto Trans Plymouth Savoys were produced.
It may look like a "big car" but it isn't. With the setup you see, it weighs about 3350 lbs.
