69 Camaro decode help needed
a customer purchased a 69 Camaro convertible that is supposed to be a SS numbers matching car. he asked about doing a LS engine swap but if it is a legit numbers matching SS he will not do the swap. I told him I know Gen-2 Camaro's but I am clueless when it comes to a 69, The car has drum brakes in the front, I thought 69 SS cars had disk but I am not 100 percent positive about that. Hear are the numbers he managed to get off of it. The car is a 06A Norwood build and there are no X codes on the trim tag. Thanks..
Mark ENGINE- Front Pad T0819HD (No VIN) TRANS- Stamp on Pan Y0M07N .
Kentucky Gold 70 SS/RS L78. 81 Z/28 Silver/Silver Int 09 G8/GXP #992 98 Pontiac GTP Daytona Pace Car #605 90 Olds Touring Sedan SUPRCHRGD L32 83 El Camino |
You're correct; power front disc brakes were included with Camaro SS. An 06A SS convert would have a trim tag X code: X11 or X55 [SS350] X22 or X66 [SS396].
It is not an SS. |
does anyone have any idea what this engine and trans are? thanks...
Mark
The transmission you don’t mention if it is an automatic, but if it has a “pan”, I assume that it is? 1st determine if it is a power glide or TH350. Then, clean the pan more and a partial VIN may appear readable. A couple of other places the partial VIN may be is along the flange that bolts to the block and on along the area where the converter dust cover bolts to. http://www.camaros.org/drivetrain.shtml#PartialVINs
69 SS/RS 396 M20 X22 Nor 12B,72B,712 bought 1979 FULL OWNER HISTORY 69 Dick Harrell tribute Day II 427 M20 4.10 X11 76 orig pnt, 711 67 Super Stock 302 Camaro re-creation Last edited by bbbentley; 04-11-2019 at 12:12 PM. |
Am curious about the lack of any X-code on the cowl tag.
Per CRG in the 'cowl tag decode' section: Quote:
Tim in NSW, Australia 1969 Van Nuys 04A Z/28 from Clippinger Chevrolet. Cortez Silver with dark blue interior. Ran at Lions Dragstrip and Pomona Raceway, with paint by Bob Kovacs of Fresno. Last edited by ZLP955; 04-11-2019 at 11:41 AM. |
Is it a L.A. or Norwood car ?
Norwood build, he is going to bring the car to the shop so I will take some pictures today. Thanks..
Mark
Ive seen quite a few 69 NOR Convertible tags without X codes. This falls in that category. Whats the VIN?
HD on the engine is a 69 350/250hp L65 with auto trans Aug 19 build Pretty sure the trans code is a Turbo 350 made in Aug of 69
1969 Camaro RS/SS Azure Turquoise 1969 Camaro Z/28 Azure Turquoise 1984 Camaro z/28 L69 HO 5 speed 1984 Camaro z/28 zz4 conversion 1987 Monte Carlo SS original owner |
Current BOK has X44 no longer being used on Norwood convertible body tags as of March, 1969. We don't know why.
If the VIN prefix is 123679N, it was a 6 cylinder. Last edited by William; 04-11-2019 at 02:08 PM. |
The Following User Says Thank You to William For This Useful Post: | ||
ZLP955 (04-12-2019) |
Hear is a picture of the engine, trans and trim tag. I can’t find a VIN stamped on the engine anywhere.
VIN-124679N6506XX .
Kentucky Gold 70 SS/RS L78. 81 Z/28 Silver/Silver Int 09 G8/GXP #992 98 Pontiac GTP Daytona Pace Car #605 90 Olds Touring Sedan SUPRCHRGD L32 83 El Camino Last edited by 70-SS/RS-L78; 04-12-2019 at 01:38 AM. |
