Old 04-28-2019, 09:18 PM
Slob44 Slob44 is offline
Default 1969 Chevelle accessory wiring help
need help identifying this accessory wire on my 1969 Chevelle SS convertible
the wire goes from the fuse box to a connector under the dash then into the engine compartment thru a hole located next to the wiper motor. Any help would be greatly appreciated .
Also - any recommendations for wire harness tape - need to rewrap my forward lamp harness and engine harness.
thanks
Attachments - The Supercar Registry pedal switch.jpg auto trans wiring.jpg 897813E6-26E4-42DD-95BE-A0B022195CD8.jpeg 1969 chevelle acc wire 5.jpg
Old 04-28-2019, 09:32 PM
SS69chevelle SS69chevelle is offline
the two wires with the grommet are for the switch attached to the gas pedal. pics from the assembly manual below. hope this helps andy
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
The Following User Says Thank You to SS69chevelle For This Useful Post:
Slob44 (04-28-2019)
Old 04-28-2019, 09:43 PM
Thank you so much - I cant believe I didn't figure that out. the turbo 400 kickdown harness!!!!!!
thanks again
Old 04-28-2019, 10:31 PM
Here is a good picture of the switch and wires connected
Picture courtesy of our very own Donnie Cornelis
https://www.yenko.net/forum/attachme...1&d=1556490501
