Old 05-26-2019, 12:01 PM
Awesome Rick. Looks great!
Best,
Dave
Old 10-06-2019, 11:55 PM
OneStopRestoration OneStopRestoration is offline
Default The end of Metal Work
It looks pretty ugly, but all rot has been removed and all panels replaced with used GM metal, next step is to acid the body panels and sand blast the rest. Sadly I thought I was done, but as you will see in a few pictured down the line I tried shrinking some dents on the roof with some heat and that just turned into a massive oil canning mess
The Following User Says Thank You to OneStopRestoration For This Useful Post:
67 Nova Boy (07-22-2023)
  #83
Old 10-06-2019, 11:56 PM
Default Underside Blasted and Primed
I ended up blasting in June. I about died doing the job in the heat.
  #84
Old 10-06-2019, 11:59 PM
Default Last Min Roof Change
Like I said earlier I destroyed the orig roof. This was a donor roof from a Buick that was a rust free Arizona car. Cant ever match original metal and how it fits.
  #85
Old 10-07-2019, 12:00 AM
Default Body Work Complete
These pictures represent a few hundred hours of block sanding and just sanding in general. Panels have been guide coated. Body seams have been seam sealed. Time for edging and chassis black paint now.
The Following 3 Users Say Thank You to OneStopRestoration For This Useful Post:
67 Nova Boy (07-22-2023), markinnaples (11-09-2019), SS427 (10-07-2019)
  #86
Old 10-07-2019, 12:01 AM
Default Chassis Black on underbody and Firewall
Fresh paint finally laid down
The Following 5 Users Say Thank You to OneStopRestoration For This Useful Post:
67 Nova Boy (07-22-2023), HawkX66 (10-07-2019), markinnaples (11-09-2019), ScottG (10-07-2019), SS427 (10-07-2019)
  #87
Old 10-07-2019, 12:15 PM
Nice
Old 10-07-2019, 02:56 PM
Wow, a ton of work. Congrats and keep it up.
John 10:30
Old 10-07-2019, 05:26 PM
scuncio scuncio is online now
That car looks incredible! Nice work.
Old 11-09-2019, 02:54 AM
Default Trunk Paint
First pic is trunk being base coated, 2nd two are after the spatter paint applied.
The Following 2 Users Say Thank You to OneStopRestoration For This Useful Post:
