Old 07-30-2019, 06:06 PM
ALLZS ALLZS is offline
Default R59 top post battery
On the original 1969 batterys where the caps yellow - white or red also the delco wording did it match the cap color or was it just black
Attachments - The Supercar Registry Screen Shot 2021-03-19 at 1.19.57 PM.jpg Screen Shot 2021-03-19 at 1.19.31 PM.jpg Screen Shot 2021-03-19 at 1.19.16 PM.jpg IMG_2323.jpg
Old 07-30-2019, 06:22 PM
Reddish orange originally..
The word DELCO was black and not painted when installed into a vehicle on the assembly line.
Over the counter taken out of the box batteries had the word Delco painted that matched the caps color.
Although my car is detailed restored to assembly line stock,I painted my DELCO wording to match the caps,as I prefer that intricate detail.
And no,it's not a topper..
The Following 3 Users Say Thank You to Mr70 For This Useful Post:
auwrestling (03-14-2021), olredalert (03-14-2021), RPOLS3 (03-14-2021)
Old 07-30-2019, 06:54 PM
Good info Rick also car looks great!
Wasn't color representative of Cranking Amps w/ Yellow being less CCA's than Red also Green less than yellow?
On replacements, were all R-Series Red and all Y-Series Yellow as I was wondering in this recent Topper thread?
https://www.yenko.net/forum/showthread.php?t=155337
Old 07-30-2019, 08:28 PM
Thanks for the info
Old 07-31-2019, 05:47 PM
roeville's Avatar
roeville roeville is offline
It looks better with Delco painted red.
Old 07-31-2019, 08:40 PM
Burd's Avatar
Burd Burd is offline
Do the “eyes” go green/ yellow?
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 07-31-2019, 10:32 PM
x33rs x33rs is offline
I assume you're talking about the Y-55's because I don't ever recall a Y-59. So yes the Y-55's are yellow and are less cranking amps. They are also reverse polarity (as they call them here) with the terminals reversed and would technically be a correct battery for a SB 69 Camaro for instance. Negative is closest to the radiator and where the hole is found on the core support for the little ground wire to attach off the negative cable.
I've always had a correct battery in our Z with the terminals reversed (technically the R59 wouldn't work anyway unless I modified the original battery cables because the ground wire to the core support isn't long enough to reach from the other side of the battery), so I just recently made my own Y-55 topper as there are none produced at this time. I started with an R-59 topper and switched the polarity insignia. My wife found a place that sold the correct decal that even came with a warranty card that I thought was funny. I painted the yellow accents myself even though the kit came with yellow decals. Pretty happy with the results.
Old 08-01-2019, 04:17 AM
Kurt S Kurt S is offline
Lotsa relevant battery info.
http://www.camaros.org/underhood.shtml#Batteries
Kurt S - CRG
Old 03-14-2021, 04:49 AM
'69Novajoe's Avatar
'69Novajoe '69Novajoe is offline
I'm in the process of modifying an R59 battery topper. It's really not a big deal to me because I'm not trying to score 100 points at a judged event but I've not been able to find out what color the Delco Eye should be!! In modifying the topper I've drilled out the Eye and replaced it with a length of acrylic rod. I'll be able to show any color I want through it. Even though I had an R59 in the car when I bought it (brand new in '69!) I still can't remember what color it was. Any thoughts??
I ain't as good as I once was, but I'm as good once as I ever was.
The Following User Says Thank You to '69Novajoe For This Useful Post:
PeteLeathersac (03-15-2021)
Old 03-14-2021, 12:42 PM
XXXGoldL34M20's Avatar
I put Green Painters tape under mine, I simply bought a NOS Delco Eye cut it down and popped it in.
The Following 3 Users Say Thank You to XXXGoldL34M20 For This Useful Post:
'69Novajoe (03-15-2021), ORIGLS6 (03-17-2021), PeteLeathersac (03-15-2021)
