Old 08-05-2019, 04:46 PM
nova67 nova67 is offline
Default 4 post drive on lift
Any recommendations on a 4 post lift? In the process of completing my new home shop and want to buy a lift. Like real world suggestions. Thanks Tom
Attachments - The Supercar Registry IMG_0055.jpg IMG_0053.jpg fivecars.lifts.jpg F82346C6-00CB-46ED-9C93-0CA329DF8023.jpg
Old 08-05-2019, 04:59 PM
tjs44 tjs44 is offline
I have a pair of Backyard Buddies now for 15 years,no issue at all.Get a jack for it also.It has came in handy countless times.Tom
Old 08-05-2019, 05:13 PM
L16pilot L16pilot is offline
I have an 8k Atlas from Greg Smith Equipment...zero issues in 10 years of service. I agree with TJS44...except get two jacks..one for each end.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
Old 08-05-2019, 06:03 PM
http://www.camaros.org/forum/index.p....msg161116#new
Old 08-05-2019, 07:07 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
My son won the Titan lift they gave away at MCACN in 2016 - it works great.
https://titanlifts.com/
Jake Dykstra
Dykstra Motorsports
The Following 2 Users Say Thank You to RPOLS3 For This Useful Post:
dykstra (06-01-2020), MosportGreen66 (06-01-2020)
Old 08-05-2019, 09:25 PM
92646 92646 is offline
I have had a Bend Pak lift for years and it has been great and it is by far one of the better lifts at the lower price point. They came out to the house and installed it because the main distributor is local to Southern California.
Old 08-06-2019, 01:15 AM
R68GTO R68GTO is offline
I've had a Bendpak HD9-XW lift for about 5 years. It is the best garage tool I've ever purchased and it has had zero issues. I also bought the RJ-45 jack which I highly recommend as it makes the drive on lift more useful for wheel/brake work.
Old 08-06-2019, 01:47 AM
the427king's Avatar
Bend pak....bought it because ramps are adjustable width and I can walk under it when fully extended and that's no easy task. It has a bigger footprint than most but well worth it
No Fisher priced toys here
Old 08-06-2019, 01:51 AM
I have a Backyard Buddy and one of the cheap 2000.00 lifts. They both do the same thing. The Backyard Buddy was over 4K but is probably built better. If you are not using it for commercial work, any of the cheap ones are probably fine. Be sure to get the 500.00 sliding jack.
The Following User Says Thank You to Charley Lillard For This Useful Post:
Tidmack (08-08-2019)
Old 08-06-2019, 02:51 AM
the427king's Avatar
I do know the legs on mine over short periods used to move a few inches when they werent secured to the concrete.And I quickly secured it with anchors. Im not sold at all on putting a full size 2500 ram pickup on a 7000 lb[or 9K for that matter] lift thats got the tires 7 feet of the ground and not secured into the concrete,even though the company wants you to believe its portable.
