Old 09-20-2019, 08:22 PM
Default '70 Chevelle intake manifold
This is something that I've been wondering for a long time. Why did Chevy use a short intake manifold on the '70 Chevelle 454 and 396 and then put a spacer between the carb and air cleaner? Wouldn't it have been better to use the '69 style intake without a spacer on top of the carb?
Attachments - The Supercar Registry FA3EFB2D-4BD0-4F6A-9782-09D33BED550E.jpeg 1406B165-A212-45E5-8DB3-35953E5D9C7C.jpeg
Old 09-20-2019, 08:33 PM
BLACKLS5 BLACKLS5 is offline
My understanding has always been something to do with fitting under the Corvette's hood, but don't take that to the bank...
The Following User Says Thank You to BLACKLS5 For This Useful Post:
big gear head (09-21-2019)
Old 09-20-2019, 08:36 PM
TopRat's Avatar
TopRat TopRat is offline
I’ll bet that the low intake is a 20-30hp loss vs the 69 style intake. I believe it was so the engines would fit under a lower corvette hood in 1970 even though the L78 and LS6 were not installed in the corvette.
70 Cortez Silver LS6 4.10 Automatic
70 Classic White LS6 3.31 4 speed
70 Astro Blue ElCamino (clone) LS5 5 speed
70 Concours Wagon Fuel injected ‘70 LS6/700R4
70 Cranberry Red LS6 4.10 4 speed
70 Cranberry Red LS6 4.10 4 speed survivor
70 classic white Malibu convertible
The Following User Says Thank You to TopRat For This Useful Post:
Old 09-20-2019, 09:51 PM
Originally the LS6 was supposed to be available in the new bodied Camaro (SS) whose hood had a lower profile than the 1969. In an effort to save money the low rise intake was used for that application (which never happened) and for the Vette (which had to wait until 1971) and of course the Chevelle SS which did get the LS6.
20 HP loss versus the 1969 HiPo intake.
Old 09-20-2019, 11:05 PM
XXXGoldL34M20's Avatar
They still did use both the aluminum and cast iron low rise intake on the Camaro that year for the L78 and L34 so Chevrolet figured to keep them low for all the models of 1970 just so it would clear the new 1970 Camaro, we all know Corvette was not the reason as the 69 hood had no problem clearing High Rise Intakes and the 1970 hood was the same for a Big Block
The Following User Says Thank You to XXXGoldL34M20 For This Useful Post:
Old 09-20-2019, 11:55 PM
Same thing I heard!! The low profile intake was more for the all new second gen. Camaro...
Old 09-21-2019, 12:59 AM
1971ls6's Avatar
1971ls6 1971ls6 is offline
I put a 1 inch spacer on my 71 and it did clear the BB hood, but was real tight.I remember in high school and the fastest car around was a 70 LS6 chevelle, it had 4 mufflers and 2 air filters,one on top of the other with no spacer. All 4 mufflers ended before the rear end, it was real loud and fast
Old 09-21-2019, 02:02 AM
Thanks. I hadn't thought of the Camaro using the same intake. Too bad they didn't go ahead and use the '69 intake for the Chevelle. I bet the L78 Camaro production numbers were way less than the Chevelle L78 and LS6 numbers.
Old 09-21-2019, 02:05 AM
markjohnson's Avatar
The low-rise pancake manifold has proven itself to be quite effective. Yeah, I know it’s an ugly intake but there was an NHRA Stock Eliminator LS6 car in the ‘70’s that compared it to the high-rise manifold and the car owner said there was no difference between them. It’s a great manifold for building a sleeper if you want to retain a flat hood on a car! I was actually VERY close to welding a 4500 carb pad to my #569 for the ultimate sleeper manifold just a couple years ago.
The Following User Says Thank You to markjohnson For This Useful Post:
Old 09-21-2019, 10:30 AM
4475~1970 LS-6 Chevelles
2144~1970 L-78 Chevelles
600~1970 L-78 Camaros
