Old 11-24-2019, 03:49 PM
70LT1Z28 70LT1Z28 is offline
Banned
Default 69 z28 front disc brake hoses 8396
does anybody have nos 69 z28 front brake hoses or does anybody knows who makes the correct hoses.
Attachments - The Supercar Registry IMG_5771 (2).JPG DSCF8363.JPG DSCF8346.JPG Brake Hose Stencil.jpg
Old 11-24-2019, 05:12 PM
67 Nova Boy's Avatar
Put the want ad in the wanted ad for your brake hoses and may get more attention there.
Allot of members are away at the Mcacn show so there may be a delay on your answer.
Dave
67 Nova Boy
Old 11-24-2019, 07:01 PM
rszmjt rszmjt is offline
Wagner & Bendix products both make correct hoses.
Old 11-27-2019, 02:44 PM
There are no hoses reproduced or manufactured which look like an original.
DOT regulations require double crimps VS single crimps as the originals had.
I had a set of hoses dated mid 70's which were single crimp however I do not believe they were produced much after that time frame.
Last NOS front disc brake hoses for a 69 F body I saw went for nearly a grand.
Old 11-27-2019, 05:15 PM
camarocards camarocards is offline
Here is my first attempt at stenciling the rear brake hose on my '68 Camaro. Not perfect and I think there's room for improvement but it's a start!
Bob
The Following 2 Users Say Thank You to camarocards For This Useful Post:
firstgenaddict (11-27-2019), mhm1966 (01-28-2025)
Old 11-27-2019, 08:02 PM
m22mike's Avatar
m22mike m22mike is offline
I had issues doing this using paint before and on Grady's Red COPO I switched to a acrylic ink, worked great, took several light coats applied with a Badger airbrush. Used the same ink for the tank stencil, tape pulled off clean.
The Following 6 Users Say Thank You to m22mike For This Useful Post:
Billohio (12-03-2019), camarocards (11-27-2019), Edgemontvillage (11-27-2019), mhm1966 (01-28-2025), NorCam (11-28-2019), scuncio (12-07-2019)
Old 11-27-2019, 08:52 PM
Mike, you are the man! Only an Italian could have come up with something like this. I can only imagine what your stuffed shells and ravioli's taste like.
The Following 2 Users Say Thank You to Salvatore For This Useful Post:
Billohio (12-03-2019), m22mike (11-27-2019)
Old 11-27-2019, 09:06 PM
Sorry I should have posted the Bendix & Wagner hoses look very similar, they are NOT 100% Correct as they have double crimps . They do work OK as far as far as fitment.
Old 01-20-2022, 07:53 PM
Reviving this thread for a question.
What type of stencil tape did you use, Mike? I have a vinyl sign cutter machine available and want to try this. I tried having a custom stamp made and couldn't get enough color saturation. I have an airbrush and would like to try with a stencil.
thanks for any help anyone can provide.
Dave
EDIT: I see Mike hasn't been on the forum for awhile. Anyone else have any input?
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
CamarosRus (01-28-2025)
Old 01-27-2025, 08:09 PM
JJR69COPO JJR69COPO is offline
Reviving this thread again, does anyone have a lead for sourcing the stencils that Mike posted photos of above?
Thanks,
Jim
