Old 11-09-2019, 10:00 PM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Looks great, won't be long before the LB starts going on! And good planning with the deck lid and cowl panel.
Tim in NSW, Australia
The Following User Says Thank You to ZLP955 For This Useful Post:
R68GTO (11-10-2019)
  #182
Old 11-10-2019, 11:45 PM
69LM1's Avatar
69LM1 69LM1 is offline
Nice, great following up on updates on this car.
/R
Rich Pern
69 Camaro COPO "Tin Soldier"
Old 11-30-2019, 12:57 AM
R68GTO R68GTO is offline
Received my parts back from Steve Gregori @ BrakeBooster.com - they turned out awesome! Booster (before/after pics) and related components are original to the car. Booster is a 9204 dated the 199th day. The ZL2 / horn relay covers and turn signal housings are also original to the car. ZL2 coil bracket is an original piece from Bentley B. Steve also did my hood hinges and latch components - also turned out great.
big gear head (11-30-2019)
  #184
Old 11-30-2019, 04:26 AM
69z2x4 69z2x4 is offline
Nice work..Looks awesome!
69z2x4s
69vette
Old 11-30-2019, 11:52 AM
Steve is really a great asset to our hobby.
Old 11-30-2019, 10:37 PM
ZLP955's Avatar
Steve's work on those parts looks outstanding, as always.
Old 12-19-2019, 12:40 AM
Default Another update....
Picked up my subframe and rear end today. Another step in the process! Took a pic of the rear mounting hole for the subframe showing original floor pan color and remnants of the sealing tape Fisher Body used for their water test. The shop will get the body on a rotisserie and get to work on the floor pans. Dents from a driveshaft explosion and the Hurst Super Shifter mods need fixed. I'll start stripping the subframe and documenting all the various paint daubs as I find them.
cook_dw (12-25-2019)
  #188
Old 12-29-2019, 01:16 AM
Default Subframe teardown...
Started tearing down the subframe over the last few days. Brake lines and stands are original pcs. The flex lines from the stands to the calipers were replaced in '97 if you go by the date on the hoses. Calipers, springs, ball joints, and sway bar links were also changed. Everything else on the subframe is original stuff including 2 pc. rotors brake shields, caliper mtg brackets and steering components. I do not have a picture of the car that shows it without traction bars. Took one snubber off (other one is still stuck) and it shows a date code of 1971 so I'm guessing they've been with the car since then.
RPOLS3 (01-02-2020)
  #189
Old 01-04-2020, 11:28 PM
More stripping/cleaning of the suspension today. Found some "ice blue" overspray from the 1970 paint job on several of the steering linkage/brake components so that confirms to me these items are likely original to the car. Also was able to find a few inspection paint dabs that I can replicate later. Found orange, blue, white, yellow, and pink in various places. Anyone else find something similar on their cars?
Glass beaded one of my disc brake dust shields. You can see where the original AD sticker was applied. It cleaned up nice......any opinions on if I should just reinstall or get them re-plated?
The Following 3 Users Say Thank You to R68GTO For This Useful Post:
big gear head (01-05-2020), NorCam (01-13-2020), ScottG (01-05-2020)
  #190
Old 01-05-2020, 02:13 AM
32KZ 32KZ is offline
Your getting this deep into it,,I'd have them redone.
Steve G did mine. Look real purty ��
Just got my hood hinges/springs, release back from him a week or so ago. Nice guy who does great work.But better call quick...
Love these build threads, know that excitement.
