Old 01-08-2020, 12:50 AM
Standard block with a good date will typically be anywhere from 3K to 4K. Hard to find dates can push the envelope. Cranks anywhere between $600 to $1200 and standard/standard grinds always seen to go towards the higher end. Are the rods and slugs still there?
But if it isn't the original block to the car its not really worth that kind of money in my opinion.
Old 01-08-2020, 12:30 PM
ALLZS ALLZS is online now
yes that would be nice to find the car it belongs to if it is still alive ??
Old 01-08-2020, 04:15 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Partial VIN will be down on the rough casting area by oil filter.
Old 01-08-2020, 08:30 PM
Unreal Unreal is offline
You sure it's not a Ford? I see a little Ford Blue paint!
Old 01-08-2020, 09:38 PM
looks like N684512 THE N&6 are very light but the 84512 is clear
Old 01-08-2020, 10:29 PM
It's good that you can read most of the vin. Most times, you can't read the vin down by the oil filter. I heard that some blocks weren't stamped with a vin, if this is true??
Old 01-08-2020, 10:33 PM
the guy that stamped must have been right handed !
Old 01-08-2020, 11:01 PM
Jonesy's Avatar
You sure about that second number being an 8? That would make this engine a bit too early for that VIN. Is it a 5 or 6?? Got pics??
Old 01-08-2020, 11:05 PM
rszmjt rszmjt is offline
Seems a lot of blocks the N is not as clear, the fonts probably wore a lot from repeated use at the Norwood plant.
Old 01-08-2020, 11:06 PM
I’ve seen a few blocks with no vin, last one was a 02 car
