Old 01-08-2020, 01:53 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
MO
Willing to bet money on it. Top tips of the M are visible, lower half of O is obvious to me.
I ain't nobody, dork.
Old 01-08-2020, 02:00 PM
Tracker1's Avatar
And I'm gonna go with T0 ? 28 MO for the whole stamp.
Old 01-08-2020, 02:49 PM
You guys are probably right about the pad stamp being mutilated for unpure reasons but who really knows. Its really a shame since the rest of the engine is awesome. It is still standard bore and looks like it will stay that way. The crank is even still STD/STD. It was greased up and stashed away 30 years ago.
Jason
Old 01-08-2020, 03:27 PM
ssl78396 ssl78396 is offline
Default Broach Marks
Originally Posted by SuperNovaSS View Post
Thanks guys.
Pete,
I don't plan to try to find the car. If I was going to do that, I would not have posted the VIN. I just thought I would check before marketing the block. As far as the suffix code goes, someone mangled it long ago for unknown reasons. That is why I never thought to look for a VIN by the oil filter. The chances of it being a COPO block is slim compared to other applications. When I was taking pictures, I realized it was not a CE block since there was no assembly date on the starter mounting pad. Then I thought it was strange there was no VIN on the pad and looked at the alternate oil filter location. Here is the pad:
Thanks again,
Jason
For those with questionable stamp's Jason's closeup pics show outstanding broaching marks!
Old 01-08-2020, 03:51 PM
Copo_Cartel's Avatar
Yenko Premier Member
I own 680415....I agree with the 8-22 assembly date.
Old 01-08-2020, 05:05 PM
Tracker1's Avatar
Top of it looks like an 8 but I can see a horizontal stroke at bottom that could be bottom 2 , I will defer to your superior knowledge of dates of these copo blocks. I pointed out the tips of the M with red arrows.
The Following User Says Thank You to Tracker1 For This Useful Post:
PeteLeathersac (01-21-2020)
  #17
Old 01-08-2020, 05:12 PM
Good detective work
Old 01-08-2020, 05:41 PM
Thank you all for all the input and detective work. For what its worth, the crank has a pilot bushing in it for a manual trans. It sounds like the car is not known. I will get the engine posted in the classifieds.
Thanks again,
Jason
Old 01-08-2020, 06:46 PM
OK, I got the engine posted up here for anyone interested:
https://www.yenko.net/forum/showthre...64#post1478264
Thanks,
Jason
  #20
Old 01-08-2020, 07:39 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Yep, T0828M*. That date makes the most sense for that VIN.
