Old 01-10-2020, 07:19 PM
camarocards camarocards is offline
Default TH400 Transmission Harness Clip
I need to know the correct finish of the transmission kick down harness clip that attaches the harness to block. It is shown as item 5 in UPC M40 A8. Wikiparts lists it with a latex finish (which I'm assuming to be rubber) yet all of the repro companies list it as natural steel.
If anyone has an original clip installed on their car and could have a quick look at it for me I'd appreciate it!
BTW...this is for a '68 L35/M40 car.
Thanks,
Bob
Attachments - The Supercar Registry IMG_2885(1).jpg IMG_2879.JPG Clip_r2.jpg
Old 01-11-2020, 01:09 PM
parkbrau's Avatar
parkbrau parkbrau is offline
Here you go. Theres a rubber coating on it. Ask Rich (Enoch) if he has another one.
Old 01-11-2020, 02:26 PM
Thank you! Just placed an order with Heartbeat City along with a bunch of other odds and end I needed so I’ll just use some Plasti Dip on it and call it a day.
Thanks again!
Old 01-11-2020, 03:38 PM
Woj's Avatar
Woj Woj is offline
The diagram shows the bolt holding the clip in place as a transmission mounting bolt. I don't believe that the clip shown will work for that. I think that particular trans wire clip is bigger.
Maybe Bill Pritchard has a picture from his unrestored 69?
Phil
Old 01-11-2020, 04:55 PM
This is the one that I’ve ordered from HCB.
https://www.heartbeatcitycamaro.com/...GM%23-2404001/
It does look a tad bit bigger and even though the description reads for use with Muncie transmission, the description of the kick down harness on their website states that this is the correct clip to use.
For $7 thought I would give it a try.
Old 01-11-2020, 05:36 PM
parkbrau's Avatar
You did the same thing I did...chasing the correct clip. Here you go, a pic of mine in use.
