Old 01-20-2020, 01:30 AM
TuxedoblackZ TuxedoblackZ is offline
Default How many ZL1’s are known to have their numbers matching engines?
Hi guys!
Curious, how many 69 Camaro ZL1’s are known to have their original numbers matching engines?
Old 01-20-2020, 09:11 PM
William William is offline
Gets more difficult to answer that question as time goes by.
For purposes of this discussion "original matching numbers engine" is defined as, at minimum, the VIN-stamped cylinder block of the original engine assembly. Components contained within or fastened to said cylinder block may or not be original to it.
Current best educated estimate: 19. There are 6 other engines/chassis that both exist but are not in the possession of the same owner. At least one of those engines is damaged beyond repair.
There are 7 surviving engines original to cars that have not been found or no longer exist. A few restored ZL1s have production engines that originated in other chassis.
Complicating the issue: some ZL1 Camaro cylinder blocks were VIN-stamped on the pad with the engine code. A common racing engine build procedure involves re-machining this area, usually obliterating the stampings.
The Following 18 Users Say Thank You to William For This Useful Post:
bigsixman (01-20-2020), Bill Pritchard (01-20-2020), Billohio (01-21-2020), COPO (01-21-2020), dykstra (01-22-2020), Hawkeye (01-21-2020), hurstL78 (01-20-2020), Igosplut (01-20-2020), JBALL (01-20-2020), KLars1 (01-21-2020), olredalert (01-21-2020), PeteLeathersac (01-20-2020), RPOLS3 (01-21-2020), rsinor (01-21-2020), SMS (01-21-2020), Tenney (01-21-2020), Tidmack (01-21-2020), ZLP955 (01-21-2020)
Old 01-20-2020, 09:46 PM
SS427's Avatar
SS427 SS427 is offline
Man I would love to see your books. You have a ton of research information you have gathered over the years on many different types of cars. Likely similar to my LS6 research I have accumulated but still neat to hear about your research. Sadly I have never put any of my stuff onto spread sheets as of yet so it is not as easy to answer some of those questions.
Rick Nelson
The Following 2 Users Say Thank You to SS427 For This Useful Post:
JBALL (01-20-2020), Tidmack (01-21-2020)
Old 01-20-2020, 10:11 PM
JBALL JBALL is offline
You read my mind Rick!
COPO 9561 X-44 Fathom Green
Old 01-20-2020, 11:07 PM
Berger L-72 Berger L-72 is offline
William, if memory serves me correct, #3 and #26 have the other car's engine.Have they ever been reunited?
Old 01-20-2020, 11:21 PM
They have not.
The Following User Says Thank You to Charley Lillard For This Useful Post:
Berger L-72 (01-21-2020)
Old 01-21-2020, 01:13 AM
Luvchevs Luvchevs is offline
Seems like a win/win for both owners to swap the motors, no?
Dave
Old 01-21-2020, 02:03 AM
When I owned # 3 I also owned his engine and tried to work a deal till I was blue in the face but the guy just jerked me around so I installed his engine in # 3. Some day future owners will come to their senses.
The Following 2 Users Say Thank You to Charley Lillard For This Useful Post:
dykstra (01-22-2020), KLars1 (01-21-2020)
Old 01-21-2020, 03:05 AM
Makes no sense... would the value double for both cars or nearly so? #26 is a Hugger Orange 4 speed. Senseless.
How nice is the #26 car?
Old 01-21-2020, 03:38 AM
I don't remember but Porterfield went to his Mom's basement and took great 35mm pics of #3's engine.
DW31S (01-22-2020)
