Old 02-04-2020, 03:52 PM
Enoch Enoch is offline
Banned
67-69 427 tri power vacuum secondaries white stripe hoses and translucent tee with part number. Excellent original survivor pieces! Also correct for NicKey cars equipped with tri power. $80. (X1) Set 2
************SOLD************
Old 02-04-2020, 04:03 PM
Banned
Original restored engine mount to block bolts....E headmarking. $50
Old 02-04-2020, 04:10 PM
Banned
65 396 L78 Z16 ONLY, straight arm alternator mounting bracket and original hardware. 3 A and 1 WB headmarking mounting bolts. $100
Old 02-05-2020, 03:32 PM
camaro cat camaro cat is offline
Rich: I'll take the engine mount to block bolts
Loren
67 RS L30 3sp 10C LOS
69 RS/SS L78 M22 02D NOR
The Following User Says Thank You to camaro cat For This Useful Post:
Enoch (02-05-2020)
  #45
Old 02-05-2020, 06:35 PM
Banned
Loren
Thanks Loren, I'll mark them sold
Old 02-05-2020, 07:33 PM
Banned
71 up small block front engine lift bracket. D stamped. $15 (X1)
Old 02-05-2020, 07:37 PM
Banned
Restored small block harmonic balancer mounting bolt and washers; TR headmarking. $35 (X1) *************SOLD************
Old 02-05-2020, 07:40 PM
Banned
Mid 68 up oil pan and transmission pan drain plugs. Excellent restored pieces. $30 each (X1)
Old 02-05-2020, 07:43 PM
Banned
Restored 68 and earlier large hex oil pan and transmission pan drain plugs. $35 each (X1) *****(A) SOLD*****
Old 02-07-2020, 08:12 PM
Banned
11 original, perfect unrestored timing chain cover bolts. Correct for small and big block. L headmarking. $35 (X2)
