  #11
Old 03-27-2020, 09:54 PM
TomN TomN is offline
I've been removing the old bushings from a set of used rear control arms I have that are boxed. Next I will need to get them cleaned up and put on a fresh coat of paint.
After that I will try and get the rear-end out from under the car. There are still some tabs welded on the axle housing from old traction arms, and the 'posi' doesn't seem to posi any longer. I would like to look at the axles and of course the car needs new shocks.
It doesn't seem sometimes like I getting much done ... but if I keep moving, I might make it.
The Following User Says Thank You to TomN For This Useful Post:
PeteLeathersac (03-27-2020)
