Old 03-31-2020, 05:35 AM
mssl72's Avatar
mssl72 mssl72 is offline
Originally Posted by McCune View Post
I used Cerakote and I hope I am happy when I fire this up.
Let us know how it holds up after you do fire things up. I'd be curious to hear.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 03-31-2020, 11:12 AM
cook_dw's Avatar
cook_dw cook_dw is offline
Cerakote is what I use as well. Assuming the surface was prepped correctly it'll be just fine. Just treat it like any other ceramic coated header. Do not break the engine in with them.
McCune (03-31-2020)
  #13
Old 03-31-2020, 12:41 PM
McCune McCune is offline
Thanks for that info. I would have made a mistake.
The Following User Says Thank You to McCune For This Useful Post:
cook_dw (03-31-2020)
  #14
Old 04-01-2020, 05:27 PM
Kurt S Kurt S is offline
Ceramic coating then top coating is the best long-term method, IMO. The coating seals the manifolds so you don't have rust bleed through. I've seen various top coatings used. One was a rub-on product that looked great.
Kurt S - CRG
Old 04-01-2020, 08:20 PM
Curious, what color is that? What was the cost to do both manifolds?
Owned since 1978 - First Car
Old 04-02-2020, 04:11 AM
It has been a minute since I got them done. I will find out what color and I think I paid about 100 bucks but I do have equipment to clean them with. I glass beaded them and then shot peened them first before I sent over to a friend for the Cerakote .
Old 04-02-2020, 06:51 PM
I believe this is the color. https://www.cerakote.com/shop/cerako...H-170/titanium
Old 04-04-2020, 11:14 AM
Mr. Chevy's Avatar
I used Slip Plate graphite coating on my Chevelle manifolds years ago and they still look great. You have to clean the manifolds well with muriatic acid before you coat them. Touch up after they on the car is easy also. If needed just brush touch more Slip Plate on it blends in.
I also have another set I had ceramic coated and then painted with Eastwood manifold grey that have held up well over the years also.
Rich
Old 04-04-2020, 01:37 PM
Thanks. I was looking through the Cerakote catalog and they have a "V" series that is rated to 1800F.
https://www.cerakote.com/shop/cerako...V-164/titanium
Was there a particular reason you did not use that?
Old 04-04-2020, 02:20 PM
scuncio scuncio is online now
This is what I ended up buying. Going to do them this weekend. Thanks for the tip!
Rich
Mr. Chevy (04-04-2020), RobR (04-05-2020)
