Old 04-15-2020, 02:05 AM
Baron Von Zeppelin's Avatar
Baron Von Zeppelin Baron Von Zeppelin is offline
If the car was selected to have Full Size Spare versus Space Saver (either/or - no cost alternate - not an invoice item) he might find a JW in the trunk.
Every little JW helps !
The Following User Says Thank You to Baron Von Zeppelin For This Useful Post:
Tracker1 (04-15-2020)
  #32
Old 04-17-2020, 01:32 AM
1967Z28's Avatar
1967Z28 1967Z28 is offline
No keys to the trunk yet but here's a pic of the matching VIN on the block and the cowl tag.
Old 04-17-2020, 05:50 AM
auwrestling auwrestling is offline
Originally Posted by Baron Von Zeppelin View Post
Thanks for sharing the find with us.
Never knew California could do that to a car.
Terrible shame it had to happen.
The 70 TA's from VanNuys plant usually have a build sheet in the rear seat springs.
He can save himself the PHS money if he gets that.
These cars pretty much document themselves anyhow when found like this.
7040570 WN Cali emission carb
cast iron intake
#12 heads
big RA exhaust manifolds
VIN on block and trans
VanNuys may have stamped VIN up higher on the block face closer to the passenger head - than the typical area alongside timing cover.
Fremont did that - fwiw.
Never seen one with power locks that didn't have power windows also.
The JW's were probably stolen.
Vin up top only on Freemont cars
Old 04-17-2020, 05:58 AM
To keep everyone from going broke buying PHS on every 68 400 Firebird you come across - there is a tiny indicator even if ALL the drivetrain is missing or swapped.
The Ram2 Roundport cars didn't go mainstream until Mid-May build dates.
That guy knew this factoid - and rolled the dice since it was a late production car.
Only 3 Convertibles known to still exist, and 13 Hardtops known
No special badging or special heater boxes or yada yada
4 convertibles and a few more hard tops I’ve got to get you up to date one of these days
The Following User Says Thank You to auwrestling For This Useful Post:
Baron Von Zeppelin (04-17-2020)
  #35
Old 04-17-2020, 08:12 AM
and Atlanta
and Framingham
No good deed goes unpunished ! lol
Bring them on over to the Roll Calls - we need 'em.
We have 3 Birdverts and 4 Goatverts documented
What colors and tranny on the #4 Birdvert ?
We have :
Blk/Blk/Blk 4spd
Red/White/Blk 4spd
Red/Black/Black 4spd
and an undoc'd potential VooDoo Green thats gone cold
Old 04-17-2020, 08:20 AM
Might can get one made from the glovebox lock at a locksmith.
Or pull the back seat and use about 3 extensions to remove the trunklid latch.
Old 04-20-2020, 11:50 PM
1967Z28's Avatar
I heard today it has been sold for $11K.
Old 04-21-2020, 12:15 AM
AnthonyS's Avatar
Nice.
Old 04-21-2020, 04:57 AM
and Atlanta
and Framingham
Every Framingham Atlanta car I’ve seen is the van on the bottom in the typical area
We have :
Blk/Blk/Blk 4spd
Red/White/Blk 4spd
The fourth car FB is green black black
I’ve seen many Atlanta and Framingham cars and they’re all Vin numbers at the bottom of the block in a typical area
