Old 04-25-2020, 02:24 AM
Muscle Car Appraisal Muscle Car Appraisal is offline
Default Disc brake backing plates
Need help with front disc brake backing plates. In search of NOS or PROPER reproduction pieces. Every repo piece I have seen (did I say every piece!) has the hole where the lower control tip comes through cut incorrectly. They are not cut "square". I know it's more of a rectangle than a square but the point is that one of the vertical cuts is canted rather then straight and when you turn full lock, or close to it, the backing plate hits the control arm and scratches the paint. The original GM part numbers that I am working with are 5463566 and 565. Any help is appreciated. Thank you! As a last resort, I'll work with what I have. What have others done to make them look day one?
Old 04-25-2020, 03:44 AM
Lynn Lynn is online now
I had my originals replated.
Old 04-25-2020, 03:52 AM
If your originals are too far gone to replate, these look promising:
https://www.ebay.com/itm/1968-1969-1...temCondition=4
There is also a seller who has one of each listed separately for less than $40 each, free shipping.
PeteLeathersac (04-25-2020)
Old 04-25-2020, 04:00 AM
Thanks Lynn. My search did not bring those up. They look good to be able to restore.
