Old 05-05-2020, 08:25 PM
It sounds like you are definitely getting exhaust in the cab/passenger area. Turndowns should help. You should be glad it sticks. If it didn’t, you would just get getting hit with carbon monoxide and wonder why you are tired and dizzy all the time. I agree with the above. Eliminate exhaust leak possibilities. If that does not do the trick then you will likely have to reconfigure the exhaust.
Jason
