Old 06-13-2020, 07:11 PM
R68GTO R68GTO is online now
Default Steering column & brake switch questions
The engine compartment side of my steering column received a shot of high gloss black back in the late '70's. I have most of it stripped off but now would like to know what should this look like? Anyone have pics of an original or properly restored one?
Rag joint connection?
Retainer cup?
Snap ring?
reverse lockout lever bushing?
Spring around main shaft?
I'm also curious which brake switch is correct. One is off my car, the other was on a 4 speed pedal setup I purchased.
Attachments - The Supercar Registry Nova 12-07 130 (2).jpg Nova 12-07 123 (2).jpg IMG_0416.jpg IMG_0414.jpg
Old 06-13-2020, 09:52 PM
Jim,
In case you are not aware of it, your lever that the lockout rod connects to is bent towards the firewall. The base of the lever should be a right angle to the column.
If you need a picture of a non-bent one, let me know and I will email it to you.
- Warren
Old 06-13-2020, 10:03 PM
yep, send me a photo, I did not notice that it was bent. Wonder what that was all about.....
Old 06-14-2020, 12:27 PM
m22mike's Avatar
m22mike m22mike is offline
Here is one
The Following User Says Thank You to m22mike For This Useful Post:
SS427 (06-14-2020)
Old 06-14-2020, 12:42 PM
Thanks Mike, great photos!
Old 06-15-2020, 11:25 PM
Anyone with knowledge on that brake switch?
