Old 06-21-2020, 08:00 PM
martyb's Avatar
martyb martyb is offline
Default Tach reading 1970LS6
Pretty sure my factory tach is reading high. 1970 LS6, M22, 4:10 rear end. 4th gear at 50mph tach is reading about 3100rpm, thinking that’s about 800rpm or more on the high side. Factory sized tires as well. Anyone seen this before, and if so what’s involved in making it accurate?
Thanks all
Marty
1970 LS6 Chevelle
1998 Viper GTS
Old 06-23-2020, 07:06 AM
ban617 ban617 is offline
If I’m not mistaken the mph would be 60 @ 3,000 rpms with a 4.10.Does your transmission have the correct speedometer gear & has the speed be verified to be correct? I was thinking 3,000 @ 50 would be either a 4.56 or 4.88..
Old 06-23-2020, 01:36 PM
martyb's Avatar
Speed has been verified by radar, speedometer is spot on.
1970 LS6 Chevelle
1998 Viper GTS
Old 06-24-2020, 10:52 PM
Remmag Remmag is offline
I just had my cluster from a 70 restored,my taçh was reading high (way high)
Per John at redline clock and gauge restoration there is a material (can't remember what it was)that breaks down over time and causes the tach to read high
This is what was wrong with my tach
I would suggest giving him a call
Good luck
Old 07-05-2020, 08:59 PM
martyb's Avatar
So I bought an Autometer tach and hooked it up today, reads 3200 rpm at 60mph, so the factory tach is way off. Another project for another day!
1970 LS6 Chevelle
1998 Viper GTS
Old 07-08-2020, 05:25 PM
WILMASBOYL78's Avatar
WILMASBOYL78 WILMASBOYL78 is online now
Post Tach reading...
With a factory F70/14 tire...you would be at 2621 rpm...at 50 with the 4.10 in high gear.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 07-09-2020, 01:17 PM
Burd's Avatar
Burd Burd is offline
It may just be a bad tach filter.
It's only Orig once
I spend a lot of money on Wine, Women and Cars, I waste all the rest.
Old 07-09-2020, 11:25 PM
martyb's Avatar
What’s involved in changing that?
1970 LS6 Chevelle
1998 Viper GTS
Old 07-10-2020, 01:33 AM
Tach filters were late 70s. No filter on this one.
Jason
Old 08-16-2020, 06:29 PM
martyb's Avatar
Jason
It’s definitely reading way high, bad ground possibly?
1970 LS6 Chevelle
1998 Viper GTS
