Old 09-17-2020, 09:29 PM
WILMASBOYL78's Avatar
Post 70 L34 Nova SS...
POP and trim tag shows this was a very early car...1970 L34 production was about half of it's big brother the L78. Overall the car looks pretty original...needs some detailing as mentioned, but the docs look solid.
Does not have the typical console most bucket seat cars have...shifter position is like the bench seat...offset to the driver's side.
Steering wheel emblem is the 69 version...may be a carry over item considering the early build. The negative cable is normally attached to the alternator bracket...again this may be an early model year item. Confused on what tires come with the car...from the factory it could only have E-70 x 14 whiteline wide-ovals.
Cortez Silver is a great color, we had a 69 L78 from Minnesota, same color.
I would place this car in the $35 - $40k range with the docs and born with driveline...if it sells for less it is a good value. It would need about $5k in professional detailing...top and bottom.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
