Old 09-25-2020, 11:42 PM
Firstgenz28s Firstgenz28s is offline
Default 1969 Camaro Curved neck rad
Can anyone help me out with any data or info on if 4 core curved neck rads were installed on 1969 Camaro L78 with 4:10 BV diff? UY tag code?
Much appreciated SYC members!
Old 09-25-2020, 11:48 PM
R68GTO R68GTO is offline
More informed people than me on this site but I believe the curve neck radiator was installed on 69 Camaro big blocks with air conditioning and 427 COPO cars only. BV is the right code for a 4.10 post in 69 unless COPO, they received a BE code rear.
Old 09-26-2020, 12:00 AM
L78 Fred L78 Fred is offline
1969 Camaro Curved Neck Radiator application was used on 396 and 427 cars with the
following criteria:
* AC
* 396/375 HP cars with 4.10 rears starting in late March early April ( I know of a couple 4.10 early March cars that came with the ZD 3 core rad)
* 427 L72 and ZL1 cars
I welcome any comments
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting
Always looking for dated L78 parts from Jan-Apr 69
The Following 4 Users Say Thank You to L78 Fred For This Useful Post:
m22mike (09-26-2020), R68GTO (09-26-2020), Woj (09-27-2020), ZLP955 (09-26-2020)
Old 09-26-2020, 12:46 AM
Thumbs up
Thank you gentlemen, the reason I ask is I know of a survivor L78 with original BV and it had the 4 core curved neck. March build date.
I have a survivor Nov 68 born with drive train and it was missing the rad. I want to replace it but want to replace with the correct unit.
Might have been due to better cooling requirements with the 4:10??
Old 09-26-2020, 01:04 AM
First Gen- Congratulations!- what is the Build date/ trim tag and final build on the NCRS doc of the March L78? O3B- I've seen with ZD 3 core-curious to see where this one falls
Also what is the build date of the Nov car- I might have a radiator for you-text me on my Cell- as well as letting me know what else you need in that time frame
Fred
[email protected]
610-585-4155
WANTED:
The Following User Says Thank You to L78 Fred For This Useful Post:
ZLP955 (09-26-2020)
Old 09-26-2020, 06:10 AM
The earliest documented with factory paper 4 core curved neck I have seen on a L78 was late april I believe it was 04C -
Dave Beems old 05A RS/SS L78 Convertible with 3.73's has a curved neck which is documented by the factory paper (now owned by Evan M.)
IIRC there was a curved neck or two installed in some L78s earlier in production - most likely due to shortage of ZD's.
Old 09-26-2020, 12:12 PM
Thanks very much SYC members. A lot of great information and more or less what I was expecting with regards to the curve neck rad.
@ Fred, my apologies, the Canadian documented Black X66 L78 build date on trim tag is 04C. Engine build date is T0403JH.
The Nov 68 L78 Olympic Gold (pre X code) build date 11D and the engine build date T1114JH.
I will give you a call today, if thats OK.
Thanks again
