Old 10-10-2020, 06:27 PM
Jamesvaughned Jamesvaughned is offline
Originally Posted by 1967Z28 View Post
Best of luck with your Dorweiler Camaro. It is obvious from the pictures it started life as a loaded car with A/C, power steering, automatic transmission, and deluxe interior with bench seat. With the tow bar setup seen on the rear bumper, I would bet this Dorweiler Camaro was bought new to be a comfortable cruiser to take a small trailer for a weekend trip to a lake or maybe take an off road motorcycle to the desert rather than to go drag racing. I would bet a hot rod engine and 4-speed was installed by somebody later on. Do you have anything showing the original CA license plate number for the car?
I would think so to, but its also got things that would signify a Dana car. And as the Original owner stated he bought it brand new with the engine and 4 speed already installed. I forgot to include, it does have the numbers matching axel with 3.73s and a posi. (Cant remember the code off the top of my head) but as I said its a mystery. At this point though the original owner has no reason to lie about it. Considering they won't even respond to my messages other than giving me the information that it was brand new with the L88.
Old 10-10-2020, 06:29 PM
Originally Posted by SuperNovaSS View Post
Thanks for taking the time to post. I'm curious how you know the 427 engine you found is the one that came out of this car.
Jason
Stamp on pad is correct, casting number is correct. All of it is matching the linked forum posting from 2001. It was also found in the same location the customer lived at the time. Vancouver WA.
Old 10-10-2020, 06:31 PM
And no unfortunately no original plate number. I can post the NCRS report if you guys want it however.
Old 10-11-2020, 07:18 PM
Astock Astock is offline
Numbers matching 3:73 posi, with a/c.
I wouldn't think you could have both, but I'm not a numbers guy.
The Following User Says Thank You to Astock For This Useful Post:
olredalert (10-11-2020)
  #25
Old 10-11-2020, 08:42 PM
----Not quite the same thing but I had a 65 Corvette with paper, 365hp, solid lifter, factory AC and a 4:11 posi rear. All on the original window sticker!.....Bill S
Old 10-11-2020, 09:24 PM
Wasn't the 327/365 HP the last solid lifter engine you could get and still order AC. Or is my memory failing me?
Old 10-11-2020, 10:24 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
In 1972 you could get an LT-1 with A/C in the Corvette
Jake Dykstra
Dykstra Motorsports
Old 10-11-2020, 10:30 PM
How about the 1972 Z/28?
Old 10-12-2020, 04:40 AM
1967Z28's Avatar
1967Z28 1967Z28 is offline
1973 was the first year A/C was available in the Z and it was no longer an LT-1.
The Following User Says Thank You to 1967Z28 For This Useful Post:
SPEEDYB (10-13-2020)
  #30
Old 10-12-2020, 02:54 PM
----Yes, Lee! In this case it's the 4:11 gear that's unusual, but 365 AC Corvettes are extremely rare. I have only seen 4 or 5.....Bill S
