Old 10-20-2020, 03:40 PM
169indy's Avatar
169indy 169indy is offline
Default 1969 Camaro Park / Turn Signal Lights
This ad is for: 1 pair of refurbished – used- (original) repaired original park light assemblies for a 1969 Camaro. These assemblies have been disassembled, cleaned, glass beaded, polished, plated, painted, reassembled and tested. These ARE originals not reproductions. Including the Made in USA stamping on back side and the GUIDE 12 SAE IP69 stamping on the inside of the housing. The assemblies have been carefully disassembled and cleaned and Zinc –Dichromate plated to 'replicate' the as manufactured appearance, you cannot get by purchasing reproductions or by painting. The wiring harness has been cleaned and preserved, The socket-contacts has been cleaned and tested for proper operation. The Packard series 56 wire female spade terminals have been cleaned or replaced (Properly Crimped). Included are NEW mounting (Like 271172) AMK nuts. 1/4-20unc w/ attached external tooth locking washer. Parking Lamp 916911, Wire Blk Turn +12vdc, Wire Ppl Park +12vdc, Housing -12vdc. (Bulbs NOT supplied) Proof of operation documented - photo attached to each lamp assy.
These ARE used parts that have been cosmetically restored . Why settle for repops, when the hard work has been done for you. Easy to swap out your tarnished worn assemblies & renew a very visible item on your vehicle.
Shipping size is (appx) 11” x 9” x 6” @ 1.5lbs
Pricing $275 USD plus shipping from ZIP 98314 (WA)
Multiple sets available
Paypal "Friends & Family"
PM me if any ?'s
(alternate) "Blem" sets avail at discounted pricing.
Compare & Save (* Core pricing and plating costs have driven the asking price Sorry Not considering Swaps at this time)
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Attachments - The Supercar Registry 100_7540.JPG 100_7538.JPG 100_7537.JPG 100_7536.JPG
Old 10-20-2020, 03:50 PM
PM Sent on the blems?
Old 10-20-2020, 05:14 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Beautiful work !! Easy to rack up hours on the details !
70 Chevelle SS-454 LS-5 M-22
169indy (04-26-2021)
Old 10-20-2020, 08:29 PM
169indy's Avatar
Thanks, there are a few Guys doing great work also (Jerry, Kevin & Mike doing these also) they are a pain & pool of cores is tough. I spend a LOT of time on them and developed sources and tech to refurbish even the nastyist of housings, but Pits a Pits not much to do about that other than try to polish it out. Rust is rust by any color. Blems are Rust housing plated so the surface finish is just not Prime, acceptable just not perfect. Beats 500$ NOS w/o Proper plating. [Opinion]
I have a RARE set of U46 housings Done but a Trade (Core swap) is Mandatory for the Fiber Set as the special-Grommet is unobtanium!
Jim
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following User Says Thank You to 169indy For This Useful Post:
ruralrte66 (10-21-2020)
Old 04-26-2021, 03:23 PM
169indy's Avatar
6 month Bump. Sold a few & Still have sets available.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 04-26-2021, 06:01 PM
Jims69z28 Jims69z28 is offline
Default Running lights
Pm sent
Old 04-30-2021, 11:20 PM
Default Parking lights
Hi Jim , received the parking lights . They look great .
Very happy with the quality of your work . Plating is perfect. The wiring , plug and grommet are in mint condition . Fast shipping and great packaging .
Thanks again.
The Following User Says Thank You to Jims69z28 For This Useful Post:
169indy (04-30-2021)
Old 04-30-2021, 11:42 PM
I too recently bought a pair of front park lights from Jim and the quality of the restoration is excellent. Thanks for a great set of front lamps Jim.
