Old 10-18-2020, 02:52 PM
x77-69z28's Avatar
Great progress Graeme! I wish my body guy had that kind of determination!
Buddy
Old 10-18-2020, 06:31 PM
Buddy
Thanks Buddy & Tim
Ron's been fairly steady on it and keeps track of the hours he spends working on it. Up to yesterday, he's clocked about 100 hours on the sheet metal work and should have that finished up around 110 hours before he turns to some cleanup of the underside (about 120 total on the metal work). Once on the rotisserie he will sand and prime the whole car before prepping and painting the jambs, openings and cowl plenums in yellow. He'll then prep and paint the bottom of the car and will also spray up along the the firewall.
He'll then get the body into high solids and will start working on the doors, hood, fenders and the front sheet metal while it's all out on body carts. When they are all ready to assemble, I will have already installed the sub frame and suspension so it's ready for the front clip to go on with the undersides of all the parts already sprayed with yellow paint where required.
Next, He will block out the entire car and ready it for base clear paint before striping it in black. Once cured he will give it a full 3 stage cut and polish to bring out the depth of the paint. It should wrap up at around 300+/- hours if all goes according to plan and it should be done in mid-November.
Note: I have decided to forego the grey primer/overspray look and will spray out satin black on the entire underside. It's not a numbers car any longer so no need to add the overspray or try to recreate everything right to factory. I'm OK with that...but I'm really still on the fence with styled trim. (ugggh)
cruiserofland (10-18-2020), markinnaples (10-19-2020), X66 714 (10-18-2020)
  #263
Old 10-18-2020, 06:43 PM
X66 714's Avatar
X66 714 X66 714 is online now
Like you said, it's your car. It will be great to see it back on the road & somebody enjoying it. It will get a lot of attention wherever you take it. Enjoy....Joe
NorCam (10-19-2020)
  #264
Old 10-19-2020, 06:09 PM
Rumbleguts396 Rumbleguts396 is online now
Cars looking great Graeme. I got to ask. Is this car a keeper for your son??? i hope i'm not putting any pressure on you. ROB
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
The Following User Says Thank You to Rumbleguts396 For This Useful Post:
NorCam (10-19-2020)
  #265
Old 10-19-2020, 09:19 PM
No pressure at all Rob
This is to be my personal keeper. My son is helping out on this one as he learns a bit more about the builds and how to do all of it. Together we will be doing a car for him right in behind this one and that will likely be a second gen car. As long as I do keep this one, it will eventually pass down to him at some point but that's a ways down the road.
G.
Rumbleguts396 (10-19-2020)
  #266
Old 10-20-2020, 10:12 PM
I recently bought another set of Yellow 714 Houndstooth bucket seats to have another spare set of used covers and seat cores, but mostly, bought these to get the headrests that were with them. Not split, not damaged and an easy clean up to become a nice set of original yellow headrests for the seats which are about to be fully restored. Score!
X66 714 (10-20-2020)
  #267
Old 10-20-2020, 10:18 PM
Also got a little care package from Mr. Lightfoot and now have the decals needed for this little Z/28. Thanks once again Don.
The Following 5 Users Say Thank You to NorCam For This Useful Post:
big gear head (10-21-2020), cruiserofland (10-21-2020), RPOLS3 (10-23-2020), X66 714 (10-20-2020), Xplantdad (10-23-2020)
  #268
Old 10-20-2020, 10:39 PM
X66 714's Avatar
Good score on the headrests. I'm going to have to dye mine to be that nice. I'm jealous...Joe
Old 10-23-2020, 01:36 AM
I've been busy working with the interior parts and the seats over the last couple of days while getting things ready for the upholsterer. He received everything earlier today and will start rebuilding the seats early next week. Thinking that should wrap up fairly quickly. Also got things going on the door panels which are soon coming from Al Knoch. I sent them a color sample of the vinyl and they will color match the ABS molded door panels so everything matches the colors on the seats and rear panels.
In other news, Ron has been busy finishing up the metalwork and has really dialed in all the door gaps, trunk gaps, and all of the seams. He's also been cleaning up the window channels and readying everything for an epoxy primer which goes on next week. The plan is to get the car onto the rotisserie this weekend. Here are a couple more pictures of the metalwork as it's nearly done.
big gear head (10-23-2020), HawkX66 (10-31-2020), L72Chevelle (10-23-2020), napa68 (10-23-2020), olredalert (10-23-2020), X66 714 (10-23-2020)
  #270
Old 10-23-2020, 05:12 PM
jbtech's Avatar
jbtech jbtech is offline
Looking great Graeme!
Jose Betancourt
67 Camaro L78
