Old 10-23-2020, 11:54 AM
RS_COPO_Canuck RS_COPO_Canuck is offline
Originally Posted by njsteve View Post
I learned that the Cuda's didn't use jute backing on the divider but since the divider had it on one side, I flipped it so the plain, cardboard side will be visible from the trunk.
Oh ok - I get it.
Still, I can't believe someone is making them like that.
You are doing great work. Loving the white with the purple!
Old 10-23-2020, 08:39 PM
njsteve njsteve is online now
I found an original set of rear window moldings on ebay for the back window. A little polishing and we should be good.
Old 10-25-2020, 05:17 AM
A12pilot's Avatar
A12pilot A12pilot is offline
Fantastical, Steve! She’s looking pretty sweet! Restification Justification of the purplest kind!
Nice work!
Cheers
Dave
Old 10-25-2020, 07:50 PM
Dave, do you recall ever seeing this J-hook contraption anywhere in the parts or did the heater box come in pieces? It's the J-hook that holds it up into the cowl. (Before I order a new one, I figured I'd ask since I don't see it anywhere.)
It goes where the arrow is.
I pulled the steering column and dash out today in order to start working on the dash components.
Old 10-26-2020, 12:47 PM
Good catch Steve!
People never seem to put those back in after removing the box.
Old 10-27-2020, 01:42 PM
A12pilot's Avatar
Nope... no J-hook Steve. Never saw one when I removed the box.
Cheers
Dave
Old 10-27-2020, 01:43 PM
No problem. Got one on the way.
Old 10-30-2020, 05:51 PM
The used set of rear window stainless arrived yesterday from an ebay seller. Much nicer than described! Already polished, too!
I outlined the entire opening in blue masking tape and then gently snapped each piece in place which is rather tricky since they have to be connected together to do this because you can't get the last piece hooked to the first one if the first one is already snapped in place. Just slightly nerve-wracking.
big gear head (10-30-2020)
  #779
Old 10-30-2020, 06:03 PM
I also decided to reuse the original dashpad since there were only two minor cracks by the front speaker grill screw holes - a common occurrence. Since it is around $800 plus $200 core charge to get a reproduction dash... and none are available now, I decided there are better things to spend my money on...like vintage mag wheels.
I wound up using some JB-Weld epoxy and gently pushed it in to the cracks with a tiny screw driver. Once it was filled, I waited for it to cure and then sanded. I then sprayed the entire dash with SEM Landau Black interior dye (I LOVE that paint - I put that s@$& on everything!). Here's the results.
Not bad from a foot away or so and now I don't have to mess with transferring the vin tag to a new dash pad (Stupid Chrysler design - lets rivet the vin to a removable part!!!)
The Following 4 Users Say Thank You to njsteve For This Useful Post:
427TJ (10-30-2020), big gear head (10-30-2020), L_e_e (10-31-2020), RPOLS3 (10-30-2020)
  #780
Old 10-30-2020, 08:11 PM
I also got the dash carrier assembly disassembled. There was a lot of crustiness on the underside so I rigged up the pool cover siphon pump and a short hose and have it circulating the Evaporust solution via a spray tip, onto the dash frame. It all drains in to a sheet of plastic that ends at the bottom of a 7-gallon bucket. The siphon pump has to be fully submerged to work, so you want that at the bottom of the bucket inside the plastic sheet which acts as a funnel to direct all the runoff back to the bottom. I got the aquarium heater in there too. The kiddie pool is there as an emergency backup in case it all springs a leak.
The Following 3 Users Say Thank You to njsteve For This Useful Post:
big gear head (10-30-2020), Woj (10-30-2020), Xplantdad (10-30-2020)
