Old 10-26-2020, 11:49 PM
It will sit a little higher than stock,but you'll be the only one that knows it.
Not anymore..
Old 10-27-2020, 03:49 PM
crash crash is offline
I don't know if you know this, but the Hurst after market shifter for the 1967-68 and the 1969 Camaro's, all the installation kit are based off the small block location...
The shifter mounting plates don't take into account the motor and trans being moved 1/2" forward and 1/2" to the right for the big block application...
Some people say there isn't a problem, then there are the people that call me for this very problem...
If you have a problem I have a mount that addresses this very problem for both the 1967-68 and the 1969 big block Camaro's for both the 27 spline and 32 spline tail housings
Hope this helps... Crash
The Following 5 Users Say Thank You to crash For This Useful Post:
169indy (10-27-2020), Hrlyfxdl (01-18-2023), SeattleCarGuy (10-27-2020), x Baldwin Motion (10-28-2020), Xplantdad (10-27-2020)
  #13
Old 10-27-2020, 11:41 PM
Motorhead848 Motorhead848 is online now
Originally Posted by SS427 View Post
I am pretty sure you can purchase a reproduction Muncie handle that is already made to fit the Hurst shifter mechanism. You won't ruin your original handle and is less expensive then rechroming the one you cut and weld. They make them for the Chevelle so likely made for the Camaro as well.
Rick, do you know where to get one of these? I’d like to do this same conversion to a 69 nova
Thanks
Old 10-29-2020, 12:48 AM
WILMASBOYL78's Avatar
Post Muncie/Hurst...
I have done this conversion for a few shifters...pretty simple. Weld the Hurst end on the Muncie handle...once it is in the boot, you can't tell. As for not ruining a Muncie handle, they make a number of aftermarket pieces that will work. For the Nova, the Chevelle handle is close...the average car guy won't know the difference.
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
