Old 10-31-2020, 01:36 AM
Originally Posted by mockingbird812 View Post
Sharp arse!!!!!
I know right? And this pace he is keeping is just as impressive.
Old 10-31-2020, 02:01 AM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Originally Posted by X66 714 View Post
Made some more progress today. I sprayed the trunk area this morning. After lunch, it was dry enough to put the back end together.
Thank you for everyone's thoughts on the wheels. For now I will leave the trim rings off...Joe
Looks great Joe. Just the sheen I plan on painting mine when I finally put some paint on the primer lol
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
The Following User Says Thank You to HawkX66 For This Useful Post:
X66 714 (10-31-2020)
  #143
Old 11-15-2020, 12:58 AM
X66 714's Avatar
X66 714 X66 714 is online now
Actually doing quite a lot of little things with the car. Not all worth posting pictures of. Waiting on finding a more correct headliner. That will help lots of other things to keep moving. Carpet is trying to relax from being in a box for so long. I did get the flaps installed onto the wheel wells which were powder coated originals. Also sprayed the underside with deadener. Had to add a couple of other items to the RH well for the factory a/c. I think the guy who put the staples in from the factory must've been hungover as he almost missed on the RH well near the bottom.
The Following 4 Users Say Thank You to X66 714 For This Useful Post:
big gear head (11-15-2020), HawkX66 (11-18-2020), scuncio (11-15-2020), ZLP955 (11-15-2020)
  #144
Old 11-15-2020, 01:02 AM
X66 714's Avatar
Also waiting for the fenders to have the striping done. At that point emblems can be attached & then I can install wheel well. I assembled the valance assy. Little by little.
The Following 7 Users Say Thank You to X66 714 For This Useful Post:
big gear head (11-15-2020), cruiserofland (11-19-2020), HawkX66 (11-18-2020), NorCam (11-15-2020), R68GTO (11-15-2020), Xplantdad (11-15-2020), ZLP955 (11-15-2020)
  #145
Old 11-15-2020, 03:41 AM
Colour looks dang perfect Joe. Looking forward to seeing your Camaro come together.
The Following User Says Thank You to L78M22Rag For This Useful Post:
X66 714 (11-15-2020)
  #146
Old 11-15-2020, 06:58 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Looking great Joe. Particularly like the replication of the factory paint coverage on the inside of the extensions and valance
Interested which inner fender splash shields you went with? I bought mine from Steele Rubber, based on other’s comments on the thickness, but am a way off installing yet. Yours look good.
Tim in NSW, Australia
The Following User Says Thank You to ZLP955 For This Useful Post:
  #147
Old 11-15-2020, 11:21 AM
X66 714's Avatar
Thanks Tim. I told my painter don't try to duplicate overspray but don't prevent it either.
I think I bought Steele also. I made staples using galvanized wire. Couldn't duplicate the curl on the back side though. Graeme is going to pass me up if I don't get it together
Old 11-15-2020, 05:06 PM
Looking great Joe...
  #149
Old 11-15-2020, 07:30 PM
napa68 napa68 is online now
Love it!!!!
  #150
Old 11-16-2020, 09:18 PM
X66 714's Avatar
Core support is basically all back together after powder coating, NOS bushings, regulator, & horn relay. I won't be able to install it all together. I just wanted to show what a fully dress a/c core support looked like. Upper seal isn't made correctly. Found a used upper seal years ago..Joe
The Following 6 Users Say Thank You to X66 714 For This Useful Post:
big gear head (11-16-2020), HawkX66 (11-18-2020), mockingbird812 (11-17-2020), NorCam (11-17-2020), R68GTO (11-16-2020), ZLP955 (11-19-2020)
