Old 10-30-2020, 02:11 AM
1967 4K's Avatar
1967 4K 1967 4K is offline
Default 67 4k
Yes on the water pump pulley, yes on the Vac advance hose should be rubber to steel line setting in a clip back to rubber into distr..
Is the carb a List 3910? Is the distributor a 1170?
Richard
1967 Camaro SS 396/375 4K
Old 10-30-2020, 02:14 AM
69L78's Avatar
69L78 69L78 is offline
The right side valve cover is not correct, it is correct for 1969.
Old 10-30-2020, 02:30 AM
RobR RobR is offline
Nice car!
The dipstick tube should be shorter and the dipstick will have a salmon color tip
Old 10-30-2020, 04:23 PM
Thanks for all the comments so far.
I have ordered the correct vacuum advance line hard tube and retainer and the correct PCV hose retainer, correct clamps for radiator and heater hoses, correct heater hose retainer and will be trying to address some of your other comments.
Carb is correct, but not correct date. Valve covers will be hard to find correct. Will look at distributor number soon. Will check out fan clutch. Need to find deep groove fan pulley.
Thanks and if you see more, please let me know.
Paul
'62 Bel Air 409/409
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Old 10-31-2020, 03:25 AM
Nice looking car. Any idea what is going on with the plug on the front side of the passenger head. It should protrude out, not stick in.
Jason
Old 10-31-2020, 05:55 AM
jbtech's Avatar
jbtech jbtech is offline
Playing spot the differences is always fun. Here are some screenshots from the assembly manual that may help.
Also I think original valve cover gaskets are silver painted cork?
Jose
Jose Betancourt
67 Camaro L78
Old 10-31-2020, 02:38 PM
tunes's Avatar
tunes tunes is offline
Those exhaust manifolds don't look right for a '67 either.
Robert
_______________
2023 Stingray Coupe Z51
Old 11-01-2020, 03:23 AM
1967Z28's Avatar
1967Z28 1967Z28 is offline
The PTB ink stamps are not visible on '67s and are hidden by the front fenders.
The Following 2 Users Say Thank You to 1967Z28 For This Useful Post:
m22mike (11-01-2020), X66 714 (11-01-2020)
  #19
Old 11-01-2020, 11:24 AM
1967 4K's Avatar
Default Ptb
Learning new things about the 4K cars. When I had the fenders off my car for painting I noticed one orange P behind the fender on the right side. That area of the cowl is still original paint on my car. Good information Jon, thanks.
Richard
Richard
Old 11-01-2020, 12:08 PM
m22mike's Avatar
m22mike m22mike is offline
P T B stamps on Gradys Red 67 for re;
The Following 3 Users Say Thank You to m22mike For This Useful Post:
DW31S (09-13-2023), Flying Undertaker (11-03-2020), olredalert (11-01-2020)
