Old 11-01-2020, 04:17 PM
MosportGreen66's Avatar
Default '70 LS6 Chevelle Value Question
Hi All,
What is this car worth?
'70 Chevelle LS6/M22/4.10s. Original white paint and body panels. Black stripes. Converted to an automatic currently for racing. Running a big cube big block now but original block/heads/intake/carb/distributor/exhaust manifolds come with car. Great pad. Assume POP and build sheet are present but I have not personally seen them. Real cowl tag. Believed to be real 12 bolt.
Thanks,
The Following 2 Users Say Thank You to MosportGreen66 For This Useful Post:
L78M22Rag (11-01-2020), x44d80 (11-03-2020)
Old 11-01-2020, 06:26 PM
lowmile lowmile is offline
Condition of the original paint and int would be the wild card.
The Following 2 Users Say Thank You to lowmile For This Useful Post:
L78M22Rag (11-01-2020), MosportGreen66 (11-02-2020)
Old 11-01-2020, 06:58 PM
What happened to the original 4 speed manual transmission? Is the original A.I.R. included?
Old 11-02-2020, 01:05 PM
Original paint looked very nice but further inspection is needed. I did not see the AIR system or transmission. Original owner had possession until recently - I'm certain the OO would know more
Old 11-02-2020, 01:18 PM
DW31S's Avatar
DW31S DW31S is offline
Does the race engine come with it? Good race engines aren’t cheap and depending on the build(er) could be worth some large coin.
The Following User Says Thank You to DW31S For This Useful Post:
Old 11-02-2020, 01:29 PM
Yes it does
Old 11-02-2020, 07:35 PM
Sean Sean is offline
Is the car caged? How are the rear spring pockets? Sometimes they develop stress cracks. Any twist on the a-arm pillars? There is usually memory from in the frame and body from drag racing.
70 LS 6 4 SPEED CHEVELLE
69 SS 396/375 HP 4 SPEED CHEVELLE
68 SS 396 CHEVELLE SS 396/375 4 SPEED
69 COPO CHEVELLE 4 SPEED #S MATCH
69 COPO CAMARO #S MATCH SURVIVOR (BLACK)
69 COPO CAMARO (BLACK)
55 GASSER L88 4 SPEED
66 NOVA "UNDER CONSTRUCTION"
70 440 SIX PAK CHALLENGER SUPER STOCKER
2001 RVW/LDR TRANS AM 1020" BBC 8 SYSTEMS
Old 11-02-2020, 11:27 PM
Originally Posted by MosportGreen66 View Post
Hi All,
Thanks,
Lots of questions, but no numbers? Assuming that it's a real LS6/M22 wearing original factory white paint (with cowl induction & black stripes) in decent presentable condition (with no material rust issues) and running (with original motor on the side), and legitimate history combined with build-sheet and POP.... I'll go out on a limb and guess it's worth around $60k US? As more details and photos come in, I could see that number going up or down.
Old 11-03-2020, 03:49 PM
SS427's Avatar
SS427 SS427 is offline
Based on the photos I have seen and knowing what it will take to put the car back to its original state (even before restoring) I would say $35-$45k and that is assuming all the original parts check out. Right now the authenticity of the paperwork and the condition of the block/heads and verifying all the original parts is unknown. You can always increase your offer but hard to go backwards.
I agree with the value of the race motor but when buying a muscle car I put little value in that and give the seller the option of selling it as a roller. If he won't then I would value the car as what a race type big block prepped driver would sell for while adding a little more due to its provinance.
Rick Nelson
Old 11-03-2020, 04:55 PM
I never value a race motor. You beat the piss out of it and it road hard.
