Old 11-15-2020, 10:18 PM
ronzz572 ronzz572 is offline
Just qurious. Is you car a Norwood 70 z28? If its A vanuys car. It should have a black floor pan. Otherwise depends on the paint used to paint over the red oxide. Also preparation they used. If it was just painted over without sanding preparation. It may come off easily. Is it flaking off? That might make it easy to remove with a high pressure air nozzle. Otherwise using chemicals may disturb the red oxide. Maybe someone else has some more to add.
1970 L78 camaro Cortez silver ralley sport under restoration
