Old 11-19-2020, 10:01 AM
3X24SPD 3X24SPD is offline
Default 1969 DZ 302 Windage Trays
Hello, was the windage tray that bolts to the 5 main cap studs on a DZ motor a late introduction during the model year? Did the 67/68/early 69 Z28's not have them? Thanks
Old 11-20-2020, 09:58 AM
I've got a DZ block with a May casting date that has the 5 studs for a windage tray. Am looking at a January casting date DZ that does not have the studs- just bolts. Just wondering if the earlier blocks originally came with a windage tray or not until later production '69. Thanks
The Following User Says Thank You to 3X24SPD For This Useful Post:
HawkX66 (11-20-2020)
Old 11-20-2020, 11:04 AM
X66 714's Avatar
X66 714 X66 714 is online now
According to everything I've read, all 1967 through 1969 302 engines had a windage tray. My 1968 302 has one..Joe
Old 11-20-2020, 11:14 AM
HawkX66's Avatar
HawkX66 HawkX66 is offline
I wonder why someone would have replaced the windage studs with regular ones. Odd.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 11-20-2020, 02:01 PM
X66 714's Avatar
Maybe they wanted the items for a different engine....Joe
Old 11-20-2020, 02:14 PM
rszmjt rszmjt is offline
All 67-69 Z28 engines came with the windage tray & studs, and Z28 oil pan. I have taken apart many original 302 motors over the last 50 years and everyone had them. I worked in a machine shop in the early to late 70,s, and we specialized in Chevrolet HP .
FWIW - Original line installed windage trays are different than a lot you see for sale, they had a round hole for the dipstick instead of the elongated slot type opening.
Old 11-20-2020, 02:16 PM
A lot of time the studs don’t clear the bar & clamp in the CK 10 honing machine or other equipment , we used to use donor bolts to torque the main caps up for block machine/ honing etc. They were also a pain because they would snag on everything when moving block around for cleaning or any other work, including storage.
The block in question may have been robbed of the studs for another block and motor combination.
Look at the bolt head markings on the 5 positions and see if the head markings differ, usually all head markings are the same on all caps on original motors.
Old 11-20-2020, 02:46 PM
HawkX66's Avatar
Makes sense. Thanks.
-Dave
Semper Fi!
Old 11-20-2020, 09:26 PM
Thanks for the info guys, much appreciated.
