  #11
Old 11-22-2020, 02:00 AM
Hadn't heard from Ron for a couple of days. He was busy doing all the little last minute things like adding the window clip pins to the sides of the rear window openings (behind the quarter sails), drilling holes for the 302 hood emblems (NOS hood), tweaking the fender gaps (I was a bit picky about them), masking off the entire car, covering the bottom in poly, and finally....cleaning the booth inside and out.
He has a few more little things to do in the AM and it will then be sprayed yellow. If that goes well, it will be masked and the stripes sprayed out as well. Then it's a few coats of clear and let it cure before the cut and polish starts. I can't wait.
napa68 (11-24-2020), X66 714 (11-22-2020)
