Old 12-01-2020, 01:35 PM
rszmjt rszmjt is offline
Jonesy, I had the throttle arm in the vice in soft jaws, I put a small amount of grease on the installed bushing/clip then worked the switch in, afterwards I washed the grease off and reinstalled the whole arm/switch. If motor is in car that’s a chore too, as not much clearance behind the cylinder head.
As noted the repo bushing/clip may be a issue, but you post says nos or original so the clip is not the problem .
Old 12-01-2020, 01:52 PM
m22mike's Avatar
m22mike m22mike is offline
I have never had much luck with the repop clip, see If someone can help with a OEM used one.
Mike
