Old 01-08-2021, 06:55 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Nice job there!
Tim in NSW, Australia
The Following User Says Thank You to ZLP955 For This Useful Post:
Vortecpro (01-08-2021)
  #12
Old 01-08-2021, 03:55 PM
dustinm dustinm is offline
I have had this done on heads before by Williams Cylinder Head and Machining in Nevada Iowa. I think the name has changed to Midwest Cylinder Head now. They have probably welded a million heads and blocks over the years by now.
Anyway very nice work Mark, I would not expect anything else from you.
The Following User Says Thank You to dustinm For This Useful Post:
  #13
Old 03-28-2021, 03:10 AM
Vortecpro Vortecpro is offline
Finished welded 840 head, 1.80 exhaust valve, 2.250 Intake valve, 11/32 stem. Peak flow was 365 CFM short port and 370 CFM long port, 260 CFM exhaust port @ 28 inches, 109 CC combustion chamber.
The Following 3 Users Say Thank You to Vortecpro For This Useful Post:
big gear head (03-28-2021), Carleen (03-28-2021), olredalert (03-28-2021)
  #14
Old 03-28-2021, 03:32 AM
RobR RobR is online now
Nice job
Different collets on the intake and exhaust valves?
How close do you run the springs to Coil bind?
Very nice flow numbers
Old 03-28-2021, 10:14 PM
Originally Posted by RobR View Post
Nice job
Thanks, I used a .050 short keeper on the intakes. I think it was .100 from coil bind.
The Following User Says Thank You to Vortecpro For This Useful Post:
RobR (03-29-2021)
  #16
Old 04-02-2021, 06:13 PM
You mention Al Mathon in an earlier post. He was the go to guy and arguably the best for cast-iron repair and welding.
Al’s welding magic was on some of the top pro stock, modified eliminator, and super stock cars. This is back when you had to run the factory cast-iron heads like the old 461, 461x and the 292 turbo heads.
Back in the 70s and early 80s before NHRA went to 500 inches for the pro stock cars, Al was bringing the decks down to 9” for racers running big block Chevy’s.
This was quite an accomplishment back before the flood of aftermarket parts available for the BBC.
Mentioning him it brought back some good memories.
