Old 01-09-2021, 07:04 PM
Default ProtectoPlate Question
I have always been under the impression that the metal portion of the ProtectoPlates was stamped at the factory, and then the dealerships would add the Dymo-tape showing the name & address of the original purchaser along with the date the vehicle was delivered to the original purchaser. Someone else recently told me they thought that even the metal portion was stamped at the dealership. Does anyone know for sure which it was?
Bill Pritchard
HuggerSS (01-09-2021)
Attachments - The Supercar Registry s-l225.jpg Resized_20200920_131633.jpeg P1010003.JPG IMG_2302.jpg
Old 01-09-2021, 07:12 PM
ALLZS ALLZS is online now
I believe it was all done at the dealer
Old 01-09-2021, 07:18 PM
How did the dealer know all the date stamps of the engine, trans, and rear? Did GM supply them with that info? Was it in a computer back then?
- Warren
Old 01-09-2021, 07:32 PM
ZLP955's Avatar
ZLP955 ZLP955 is offline
From http://www.camaros.org/numbers.shtml#POPCodes
The Protect-o-Plate (POP) is a small stamped metal plate that was provided with each vehicle by the factory as part of the warranty and service package. It was atttached to the vehicle's warranty booklet. When the vehicle was sold, the dealer added the customer's data name and address to the metal plate via Dymo-type stamped plastic adhesive labeling.
Tim in NSW, Australia
The Following 2 Users Say Thank You to ZLP955 For This Useful Post:
Bill Pritchard (01-09-2021), Woj (01-10-2021)
Old 01-09-2021, 07:33 PM
When I owned the orig. 67 Pace car I found just a bare Protecto Plate in the glovebox. It had been stamped but not in a warranty booklet.
The Following 2 Users Say Thank You to Charley Lillard For This Useful Post:
Old 01-09-2021, 07:49 PM
luzl78 luzl78 is offline
Originally Posted by charley lillard View Post
when i owned the orig. 67 pace car i found just a bare protecto plate in the glovebox. It had been stamped but not in a warranty booklet.
mq. L78
Old 01-09-2021, 07:51 PM
7TL34 7TL34 is offline
On my 1970 Camaro (which I bought new) I have a metal plate stamped by the factory, and the dymo type plastic tape stamped by the dealer, & stuck to the metal plate. However, I have a1965 GTO with a smaller metal plate stamped by the factory, and another separate
metal plate stamped by the dealer. The GTO was one family owned before I got it.
Old 01-09-2021, 09:51 PM
Beginning in Aug or Sept of 1969 the factory affixed Federal compliance decals were imprinted with the VIN using the POP through a type of transfer like the old credit card rolling imprinter - The date in the upper right is a slightly larger size and wouldn't change except by the month.
Some of the compliance stickers have at least part of the Suffix codes from the engines and transmissions visible. (as Illustrated below)
(in the photo below you can also see part of the ink ribbon transfer in the center under General Motors)
The clear overlay was applied when the blue decal was affixed in the door jamb.
The Following 2 Users Say Thank You to firstgenaddict For This Useful Post:
Bill Pritchard (01-09-2021), PeteLeathersac (01-14-2021)
Old 01-09-2021, 09:53 PM
Are there any MQ's built prior to 0303
Old 01-09-2021, 09:55 PM
I think grumpys car was the same date. This is the earliest date I believe
