  #11
Old 03-18-2021, 07:38 PM
Originally Posted by Keith Seymore View Post
One of the projects dad worked on when he was in CPC Advanced Manufacturing Engineering was the second generation Fiero frame (aka "P2" chassis).
It was to be a space frame construction, and one of the options was a welded tube build - or - tubes with cast connectors at the nodes. As a result he traveled to Schwinn, Hitchner Casting (they make Crane rocker arms, among other recognizable castings) and Mr Gasket to review their various manufacturing processes.
K
(The ended up going with a combination of stamped aluminum and hydroformed aluminum tube, and built and tested a couple parts, before the program was canceled).
There was another BMX cvompany in the late 70's early 80's named I believe VITUS they manufactured Aluminum BMX bikes which were glued together using forged or cast connectors with T6 tubes if not mistaken. EXTREMELY LIGHT and strong.
