Old 05-12-2021, 02:59 AM
60sStuff's Avatar
60sStuff 60sStuff is offline
Default Wire Wheel Disc ‘extension’.
This ‘65 was ordered with the “wire wheel disc covers” which requires the valve extensions.
There were two of these 1-1/16” extensions in the console glove box when I purchased the car.
Fortunately I was able to find a couple more of that design and length.
Kelsey Hayes wheel information.
14 x 6 JK
Date, 9-64
The Following 2 Users Say Thank You to 60sStuff For This Useful Post:
427TJ (05-15-2021), markinnaples (05-17-2021)
  #52
Old 05-12-2021, 03:18 AM
Pro Stock John's Avatar
Pro Stock John Pro Stock John is online now
Amazing car, I've read this thread twice since you posted it. I had a '64.
The Following User Says Thank You to Pro Stock John For This Useful Post:
60sStuff (05-12-2021)
  #53
Old 05-12-2021, 03:23 AM
60sStuff's Avatar
Default Spare tire and Wheel
BFG Silvertown 7.75-14 tire.
This spare had been slightly used at some point.
The solid Black (code A) wheels on this car has a “W” and “GM” stamped on the face along with a “6 9” at the valve stem.
Correct DILL 627 valve cap.
Lead wheel weight.
427TJ (05-15-2021), olredalert (05-12-2021)
  #54
Old 05-12-2021, 12:21 PM
Love everything about this PONTIAC
Thanks for sharing.
  #55
Old 05-12-2021, 12:50 PM
TimG TimG is online now
I love these little details about cars, and the letter from Pontiac is great.
  #56
Old 05-12-2021, 01:47 PM
napa68 napa68 is offline
Thank you so much for taking the time to document all of these little details. It's just as entertaining as it is informative!
Tim
  #57
Old 11-29-2021, 08:57 PM
60sStuff's Avatar
Default Glass Codes
Question, during a “Vintage Certification” on a Unrestored Survivor automobile, does the judging crew look at all the window codes to determine if they are dated correctly for that particular car?
I recently completed the full walk around with photos of all the windows on my early ‘65 GTO.
I expected all 8 windows to be correct as when this car left the Baltimore plant in late 1964.
The clarity varies, as some are dark and easy to read, as others are light and difficult to photograph.
These glass codes line up correctly with a range of June, July and Aug. of ‘64.
Invoice date on this car is Nov. 6, 1964.
As mentioned earlier in this thread, this particular car may have been impacted by the 30 day General Motors (Sept. 25 ~ Oct. 25 of 1964) strike.
LOF on the two wing windows and PPG on the rest of the glass out of the BAL plant.
Interesting, the LH door glass and 1/4 glass are read from the outside opposed to the others being read from inside.
My ‘66 built in Fremont is the opposite.
PPG on the wings and LOF on the rest.
The Following 4 Users Say Thank You to 60sStuff For This Useful Post:
grantprix (12-01-2021), olredalert (11-30-2021), PeteLeathersac (11-29-2021), Tenney (11-30-2021)
