Old 06-08-2021, 07:52 AM
Originally Posted by hogdaddy View Post
I came across this video today and I'm thinking seriously about using muriatic acid on this panel instead.
I still can't imbed a video here.
https://www.youtube.com/watch?v=EY7_7uey1ac
To imbed a You Tube video:
copy everything after the =
Then paste that on your post, highlight it and press the You Tube icon - must be in advanced edit to get to it.
Presto:
hogdaddy (06-08-2021)
  #12
Old 06-08-2021, 12:37 PM
Burd's Avatar
Burd Burd is offline
Installing an embedder is the way to go, I still can’t get it to work.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 06-08-2021, 01:49 PM
Muriatic WILL etch the metal. It needs to be diluted a lot to be safe for the metal and then it works much slower than his results.
If you are going to use it, have a large enough tub to submerge the entire piece to avoid etch lines like I got soaking my fenders one side at a time. The etch will be uniform and if rough enough, supply the "tooth" primers want to grab the metal (substrate) That would eliminate needing to hand sand with 80 grit.
Old 06-08-2021, 02:29 PM
Muriatic Acid is a wonderful thing.
Old 06-08-2021, 03:39 PM
hogdaddy hogdaddy is offline
I don't see the Youtube icon on my desktop computer. Does this only work on phones?
Old 06-08-2021, 03:50 PM
He mentions a stronger muriatic acid and Lowe's sells it I believe but he uses it full strength in video.
Old 06-08-2021, 04:44 PM
Do this:
On the main screen choose "UserCP" (User Control Panel)
Then Choose "Edit Options"
To make your message screen look like this...
Go to the very bottom of the Edit Options screen and choose "Enhanced Interface - Full WYSIWYG Editing" then save the changes. You should be good to go!
  #18
Old 06-08-2021, 05:12 PM
I didn't watch the whole thing, cause I can't stand all the hype and BS. If it is already diluted, it may be fine, but don't leave it unattended for long...keep checking it often and remove as soon as it is clean.
Old 06-08-2021, 05:25 PM
I would never use Muriatic acid on stamped steel panels, especially if there are any welded joints (such as at the bottom of this front valance. You will likely end up with paint bubbles a couple years after paint is applied.
JMHO that it is not worth the risk.
Old 06-08-2021, 05:30 PM
I have used it (full strength) previously on cocktail shakers years ago and primed and painted them afterwards with no issues to this day.
